Question about Panasonic KX-TGA101S Cordless Handset
It said base no power - Panasonic KX-TGA101S Cordless Handset
Posted by ferasshawi on
MSwerk
    New Friend:
Remove then replace the batteries from the hand set. You should now get dial tojo.
Posted on Sep 16, 2011
  • MSwerk Sep 16, 2011
    Got to watch those fingers. Tone not Tojo
j Hsieh
    New Friend:
I have a pansonic KX-TG6513 with answer machine, bought it used, got home it shows "base no power", I tried with all 3 other phones showing the same massage, even open the base unit to check for loose wire/connection. It turns out the handset is been off for a long time, after I replace the new battery I need to re-registraion the hand set to link with the base unit. Here is how to. check both base and handset unit all have power, phone cord is in both side "wall and base unit phone". On the handset go to "Menu" then under "initial setting" find the "registration", press select it will go to "register handset", press select, it will show you need to press and hold the locator button on the base unit for 5 seconds until you hear a beep then you press ok on the handset to establish the connection. This should reconnect your handset to the base unit. This method also apply when you try to add an additional handset to the base unit.
Posted on Jan 28, 2014
Anonymous
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi
I have just bought a Panasonic KX-TGA641ET Additional DECT Handset which I had hoped (from reading advice from a retailer on line) would be dected as an additional handset to my existing Phone System - KX-TCA128E. unfortunately I have failed thus far to connect the new handset. Please help!
Kind Regards
Terry Follen
[email protected]
Posted on Mar 22, 2011
Our phone says base no power
It is very simple, either the base station is defective or the base station power adapter is defective. I would go with the base station, but check the phone power adapter with a volt meter for correct voltage output as well..
Jan 20, 2017 | Lands Phones
No dial tone?
check power plug at base is plugged in and turned on at power point ( this has happened twice in last two days on my phone base power pack - by others unplugging it)
Check line cord at base unit is plugged in too
base phone not working suggests no power on base and phones battery has gone flat .
Nov 18, 2016 | Lands Phones
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
Try the following:
1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc..
2/ Reset the telephone base. Unplug the electrical power. Wait for
approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset.
3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize.
Manual available here:
at&t el52300 manual
-Charles
Jul 02, 2016 | AT&T El52300 Cordless Phone
I have model KX-TGE 270 and the handset on base says "base no power"
your base should have power to get the handset working.make sure your base has power , may be loose connection, pull the power cord on the base and insert back and see. or try another outlet to see if any power goes to the base.
Dec 02, 2014 | Lands Phones
Hi phones suddenly stopped working and says 'base has no power' even though all plugged in OK... help?
If the base has no power, then it is either the power adapter or the base itself. Power adapter can be tested using a multimeter on Volts. Value must be within half volt from specifications. If the voltage from power adapter is correct, then the base is defective. In that case call the number on phone manual to get the part replaced, those parts are not repairable.
Jul 07, 2011 | Panasonic KX TG6512 19 GHz Twin Cordless...
My Sony cordless handset doesn't work and displays "S/C Invalid".
  1. Place the handset in the base.
  2. Unplug the AC power adapter from the telephone base.
  3. Disconnect all the telephone lines from the telephone base.
  4. Allow the telephone base to remain without power for 1 minute.
  5. Connect all the telephone lines to the telephone base.
  6. Plug the AC power adapter back into the telephone base.
Aug 31, 2010 | Sony SPP A973 Cordless Phone
VTech 2651 base (2.4GHz) +3 phones - base not charging, has power
email me, i may have a bbase for you, put vetech phone base in the subject line. thanks
tim
my email [email protected]
Nov 04, 2009 | Vtech Lands Phones
I'm trying to calculate base number equation
You are victim of a confusion between terms. Base-n calculations are calculations using various numeration systems (bases) : binary (2), octal(8) hexadecimal (16) and decimal (10). What you want is how to calculate powers, logarithms, exponentials and these have also the notion of base; Log in base 10 is the common log, whereas natural logarithms, are logarithms in base e.
Back to your exemple: 5 times 5 and raise the whole to power 3?
In that case [(] 5 [x] 5 [)] [^] 3 or [X to the 3] if you have such key or
25 [^] 3, because 5x5 = 25
5 times (5 raised to power 3)
5[x] [( ] 5 [^] 3 [)] or 5 [^] 4 because of the rules about products of powers with the same base.
Hope it helps.
Feb 17, 2009 | Casio FX-115MS Plus Calculator
Panasonic KX-TGA101S Cordless Handset Logo
11,079 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
