I had the same problem, I changed the daylight savings time on mine and it worked untill summer, then it happend again. Finally mine quit working altogether. P.S. when this first happend samsung didn't even know what the error coded meant. It is an engineering code, meaning service engineer I believe. If it is beyond the year warranty your hosed, it would cost so much to try and fix your better off buying a new one.
I am a housewife that NEVER touches this stuff...but I fixed this one myself! Take off the top front vent (two screws on top) Then there is one screw above keypad panel. Take that off and CAREFULLY pulled back key pad panel. I then carefully unplugged all connections making sure I could get them back where they belong. I noticed some moisture and used condensed air to carefully blow it all out. Then I let it sit open over night to air out. Put it back together, plugged it in...and yippee it works like a champ now....hope this helps...atleast worth a try to start with.
