SOURCE: Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
SOURCE: Constant Paper jams on CLX-3175FN
Where is the jam happening? Is it right at the print output tray? If it is, where only about 1/3 of the paper will comeout and stop printing, the 2nd paper sensor right about that area is defective. If you're unit is still under warranty, a service call to samsung is needed to get the part replace.
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
SOURCE: My samsung CLX 3175FN printer
You can get this from
Hornet CS Ltd
11 Avondale Road
Newport
Isle of Wight
PO30 1HE
tel: 0845 226 0369
Part Number CLT-R409
Follow this link: http://www.hornetcs.co.uk/p/?prd=OSAL-CLT-R409&sid=06 to buy online
SOURCE: My Samsung CLX-3175FN is asking
You will have to purchase an new imaging drum. It is the shiny green metallic cylinder in the bottom back of the printer. It is the last piece to come out when you remove the toner waste unit and then all the toners. It sits on the very bottom/back of the toner bay. They are not cheap but do not need to be replaced very often and it will give like new printing after.
