Sony HDR-XR200V High Definition AVCHD Camcorder Logo
Posted on Oct 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My problem is blurry photos. Problem occurs when taking pictures over a few feet away. I have tried manual focus, with no improvement. The pictures are blurry but I don't think it's a focus problem. No flash/flash doesn't make a difference
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Oct 25, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
218860
Points
3782
You haven't switched the camera to "macro" mode by any chance? Flash should eliminate camera shake as the source of the problem. If it isn't macro mode, then it sounds like a fault requiring the repair shop.
Blurry pictures
Is your camera in the macro mode?
There's a slide switch on the end of the camera, near the USB slot. Slide it from the flower to the mountain, then take a picture of something at least three meters (ten feet) away. Is it still blurry?
tip
How to improve picture quality of Digital Camera
Slow down the shutter speed of your digital camera. Whenever you must take a photo in a low light environment decrease your shutter speed. It is virtually impossible to take a blurry digital photo with a an extremely slow shutter speed. Even if your digital camera has an automatic or semi-automatic mode, slowing down the shutter speed will still produce a better digital photo. <br /> Wait until your digital camera is completely focused. Most digital cameras will notify you that they are focus ready by a blinking light, on screen indicator or a noise. Confirm that your digital camera has locked onto your desired target before pressing the shutter release button. Some digital cameras may have trouble focusing on subjects easily. If this happens use an auto focus mode to produce a better digital photo. <br /> Prevent your digital camera from shaking. Shaky hands or sudden movement will definitely produce a blurry digital photo. When holding your digital camera, make sure the viewfinder is firmly pressed against your face before snapping a digital photo. If you do not have image stabilization on your digital camera, then think about investing in a tripod. This will allow you to steady your digital camera for the perfect shot. <br /> Make sure the digital image is definitely a blurry one and not just a soft image. On many occasions soft images are mistaken for blurry ones. Soft images occur often with digital cameras. When printing these images, the softness rarely shows through. You will be able to easily edit these photos by sharpening the details for a better printing experience. <br /> Take your time. Instead of rushing to take a digital photo, set aside enough time to shoot your image. Hurrying up will not produce an excellent digital photo. You don't need to be overwhelmingly slow when taking the photo, but try your best not to take a hasty one.
on Dec 31, 2010 • Cameras
2helpful
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Camera will not focus correctly. when shutter button is pushed half way down the picture goes blurry, and if you take the photo it actually turns out blurry.
If you are taking close up photos, you might have to use the "macro" setting. The auto focus only works down to around 5 or 6 feet I think. I have an earlier model of that camera. I use mine for normal use and also close up for work related photos.
1helpful
2answers
Photos are fuzzy. At the time it takes 52 picts. a round. Would they be sharper if I reduce the picts?
Hello MaryRoth,
Photos are fuzzy due to many reasons and the main two reasons are that the subject is out of focus or the subject or the hand shake during the time of taking the snap.
Please make sure that you select appropriate picture modes (Macro, Portrait, Landscape etc..) when taking snaps. Make sure that when you press the click button half-a-way (known as AE mode), the subject is still in focus.
Try using a Tripod stand in case the hand is not steady or try increasing the shutter speed if its an SLR camera. That should help.
Let me know if that works.
Regards,
Srinivas
Apr 27, 2009 • Cameras
1helpful
2answers
Blurry picture
What make and model of camera do you have?
In general, you need to make sure you aren't shaking the camera or focusing on something that's too close. Also, you need to have adequate lighting or enable the flash.
If it's a new camera, make sure you have removed any protective stickers on the lens and display.
Many times people move the camera while snapping the picture. Sometimes they don't even know they're moving until later.
Put the camera on a table or other stable, stationary object.
Point the camera at some large object at least five feet away and make sure no other close objects are in view.
If the camera has a timer mode, engage the timer mode and press the button to take a picture. Otherwise, hold the camera steady on whatever it's sitting on and press the button to take a picture.
If the picture is still blurry after a few attempts, then the check the camera lens to see if it's dirty. If it's clean, the camera probably needs to be serviced. If you have a product repair/protection or warranty from a retailer, check with the retailer on how to get it serviced. If not, check the manual and manufacturer's website to see how to get it serviced or repaired.
Apr 06, 2008 • Cameras
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
My picture is blurry or out of focus.
ake sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. See Chapter 4 for more information about how to change the shutter speed from the LCD menus. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
What should I do if the picture is blurry or out of focus?
Make sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode (2.3" zoomed to wide). When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. On the PhotoPC 3000z you can also use Program (Sports Mode) or Manual (Shutter Priority) to increase the shutter speed. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
