JBL BP1200.1 Car Audio Amplifier Logo
Posted on Oct 25, 2010
HOW DO I RUN ONLY ONE CHANNEL IM RUNING 1 15'' SUB DVC 4OHM AND IM WONDERING HOW TO PUT THE WIRES ON THE AMP CAN I BRIGE IT
How to wire a 12inch 4ohm dvc sub to 2ohm
Take two wires, equal length. Reach from positive of 1 coil and hook too positive of 2nd coil, now do the same with negative, neg to neg.. Then pos of sub to amp. And neg of sub too amp.
Can i run a 4ohm.dvc & a 3ohm.svc off of a mtx te 801d
if you wire the 4 ohm sub voice coils in parallel you will have a 2 ohm load for the Image Dynamics sub, the JL sub only being single voice coil will of course be 3 ohm.
You cannot connect them both to the amp you specified as when connected the total load will be less than 2ohms and the amp will either trip it's protection circuit or could damage the amp, My suggestion is to try each sub separately and decide on the one you like the most or obtain a matching pair for the 4ohm DVC.
I have 3 10" clarion
If your sub woofers are DVC 4OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.67OHM load or if connected Series/Parallel then you would have a 2.67OHM load. If your sub woofers are DVC 2OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.36OHM load or if connected Seies/Parallel then you would have a 1.67OHM load and Series/Series a 12OHM load. So if your sub woofers are really DVC, it would be impossible that your amp would be playing 4OHM. The numbers just don't add up. There are amplifiers out there that can deal with 0.50OHM loads but expect them to be on the pricey side, but fairly so, because mostly higher end brands tend to manufacture them and are usually pretty good. Remove 1 of the sub woofers. If i knew what the subs where 4 or 2 OHM DVC and what amplifier you are using i would tell you how to connect them for the best possible result. hope this helps dreamsystems
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
4 ohm sub wiring
you can run them on each channel..ive heard that putting them togethor sounds slightly better but ive never noticed a difference and i work at a audio shop
1helpful
Adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
How to brige 4ohm 12"sub primire by prioeer double coil
You can't run TWO subs on the bridge!!!!! You will destroy the amp! Put ONE sub on EACH channel.
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
