I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Hi
As you have already cleaned and checked the arm for any
clogs then please make sure that all holes are open. Use a sharp metal pin to
clean the holes on the top spray arm. Make sure the water pressure is not low. The
top arm spins freely. If not then check the bearings for the arm. Hope
this helps...please post back for further assistance.
Daniel
Hi
Please check if something is blocked near the top
spray arm, also make sure that all holes are open. Use a sharp metal pin to
under the screen and you'll
need a Torx screwdriver to get to it after you remove the spray arm and screen.
Check to see that the path it travels is clear. I have seen these get blocked
up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if
they are producing extra friction while the spray arm spins. Hope this helps...
Please post back if you need more assistance.
Daniel
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Hi
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
