Well, at first there were times when the camera would vibrate/shake when I turn it on, but it would eventually go away. Now, it vibrates and shakes every time i turn it on. I can't take any more photos because of this.
If you are talking about a hand held video camera it is your hand shaking, it becomes more apparent if yo zoom in on something very far away. If you camera is equipped with a video stabilizer function, make sure it is enabled. If you are talking about a web cam, make sure it is secure and there is no extreme vibration going on in the room. Even loud audio especially with a cranked up sub woofer could prvid eenough vibration to affect your video
On Sony T100 and similar, its the vibration canceling unit, i had the same problem. if you have good hads you can fix it.( on your oun risk) 1) disasamble the camera, you will see black plastic box inside, this is he lens unit. 2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly 3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws. you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake) 4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart. remove one of the pins on wich it slides, and take the lens and the magnet out. 5) reglue the magnet and reasemble the camera. 6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply. i have a document with pictures explaining the process .
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
the sstepper motor of the focus assembly has slipped out of its track. that motor is a very powerful one which can cause the vibration.
once u change the mode to take the picture the motor should run in both direction to make some calibration.
you cannot disable it. in the preview mode the optical assembly returns to it closed position and then the motor is switched off.
since it is a cybershot you need to be very careful in handling the camera if you have any plan to open it. it is recommended to be taken to the nearest service centre. any way the wheels might need replacement
It's actually, believe it or not, an anti-dust mechanism. All Sony Alpha A100's (mine included) do a little shake/vibration to help keep the dust off. It's nothing to worry about unless it lasts for more than a second.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
