Question about Kenmore 98702 Stacked Washer/Dryer
The automatic fabric softener dispenser is not emptying, how do I remove the little drawer in order to try and clean it out. The soap dispenser is working fine. The units are appr. 5-6 years olde and I have never had a problem. these are full size, front loading machines and the washer is the kind that senses how much water to use. Marylin
Posted by marylin_bole on
5 Related Answers
Dov Dror
  • 641 Answers
SOURCE: automatic fabric softener dispensor not emptying
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle)by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Aug 06, 2007
Anonymous
  • 213 Answers
SOURCE: Problems with fabric softener
you either have low cold water pressure being caused by the screens on both ends of the cold waterline being clogged by sediment or one of the solinoids for the water inlet is bad. try removing cold water hose and cleaning both screens if that doesnt help youll need a solinoid
Posted on Nov 20, 2007
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
dazmaraz
Darren Moxam
  • 67 Answers
SOURCE: WFLI2440 FRONT LOAD FABRIC SOFTENER NOT DISPENSING
your soap drawer is most likely to be blocked , the only true way of clearing the blockage is to take the soap dispenser completely out . you will see that all the jets will be blocked ,you can do this before taking it all apart by taking the drawer out band looking up, if it looks clean ie; no black gunge then it may be a water valve problem, as the cold fill side has 2 internal valves both have come on together to clear the conditioner compartment.
Posted on Feb 15, 2008
Anonymous
  • 97 Answers
SOURCE: Dispenser still full of water and fabric softener
hiya
this could be caused by a faulty cold inlet valve if the detergent is not being taken away. however if the detergent iis being taken away then the valve is working ok as it fills the compartment with water lifting the detergent out and into the washing machine.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Fabric softener drains out, but pumps water back into dispenser after draining?
Hello friend, thank you for allowing me to assist you!
It is a normal operation to receive water inside the dispenser after draining. This is part of the siphoning action of the drawer. You would just remove the drawer and empty the water out, then reattach the dispenser drawer. I hope this is helpful. -Matt
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
I have a Bosch Nexxt washer, model number WFMC 32000C/01. Yesterday I noticed the fabric softener was still in the dispenser after the cycle was completed. I cleaned out the dispenser and ran another...
Could be the fine holes in upper dispenser are blocked. Remove soap dispenser drawer and use a washing up brush to clean upper dispenser, replace drawer & test. If not could be upper dispenser or inlet valve.
Jan 10, 2011 | Bosch Washing Machines
Fabric softener does not drain out but remains in the tray. Tray fills with water and stays there. I have cleaned drain hole at tha bottom with pipe cleaners and it is clear! This is on a front loas...
I'm having the same problem with the fabric softener dispenser not emptying and filling with water. I, too, have cleaned everything out and there are no clogs. What's the solution?
Dec 29, 2009 | Samsung WF203ANW Front Load Washer
My machine is collecting water on the fabric softener dispenser and also on the soap dispenser
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 23, 2009 | Kenmore Washing Machines
Fabric Softener dispenser is holding water that will not drain.
remove soap drawer and dismantle softener syphon assy , clean and reasemble , whilst drawer is out check water jets in roof of soap container , clean all but especially ones over the conditioner compartment, replace drawer and re-try.
Nov 09, 2009 | LG WM1812C Front Load Washer
Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
May 23, 2009 | LG WM1814CW Front Load Washer
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Feb 15, 2008 | Bosch WFLI 2440 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
75 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
