The switches on these things don't last forever. They wear out with use, and the snooze button probably gets pressed a lot. Sounds like yours has reached the end of its life. They are the same kind of tactile switches commonly found on VCRs and TV sets, and it is possible to replace them. However, unless you have a spare switch and can do the repair yourself, you would be better off replacing the clock radio. The cost of repair, if you can find someone who even would take it for repair, would likely exceed the replacement cost. Small items like this were never meant to be serviced. Ask around, though. Maybe you have a tinkerer friend who could take a shot at this for you.
Thanks for using Fixya!
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time;
