Question about Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON AN ANNUAL BASIS FOR THE PHASER 8500 / 8550. (095205219357) PC Notebook
My xerox workcentre pro 420 shows me code u4, how do i solve it
Posted by 0732000532 on
sandeep gavhane
  • 101 Answers
P/l call to xerox cust care center this bater solutions
Posted on Oct 25, 2010
jame
    New Friend:
Xerox 420 pro - U4 error
Hi all. I have this xerox 420 pro machine wich came with an U4 error. I reset it and it worked well for a couple of days. After that, the copier was moved and after aprox 5 copies, i showed U4 again. U4-1 to be exact. I'm not familiar with this type of machine so any advice would be really usefull. I suspect the thermal fuse, according to the manual. But i don't know where to find it. If that is the problem, can the fuse be ordered by itself or do i need a new fuser?
Posted on Jul 02, 2013
3 Related Answers
Anonymous
  • 53 Answers
SOURCE: my machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
Posted on May 29, 2008
Everett Lin
  • 990 Answers
SOURCE: Xerox WC Pro 423 fault code U4-6 & U4-4
Hello sir; The U-4 code all are fuser problem, there haave noway to fix it the only way is replace the fuser unit
Posted on Aug 23, 2009
Everett Lin
  • 990 Answers
SOURCE: WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Posted on Feb 07, 2009
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Feb 19, 2018 | Xerox Office Equipment & Supplies
How do I reset error code u4 using the control panel?
Switch off the M/C then press & hold zero button & on still when screen will display (---) then press '10' start button '1' start button. now your M/C showing 3 so you change it press '0' button then switch off &on
Oct 10, 2014 | Xerox Office Equipment & Supplies
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
My machine shows a U4 code
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
1,183 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
