SOURCE: have an urc-3220 remote control
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: program Universal Remote URC-R6
hi.. I am trying to program our Universal R6 remote to our emerson ewd2202 dvd/vcr but nothing seems to work. I have tried the list of codes given for emerson in general... but not sure if there is a way to figure out what the exact code is for a emerson ewd2202 code.
