Question about Iomega ScreenPlay Pro MP3 Player
When i connect my screenplay director to my tv the picture is in black and white, how can i fix this problem?
Posted by damienmullin on
GreatAbyss
    Habit-Forming:
  • 91 Answers
Confirm that the ScreenPlay Director is correctly connected to video input on your TV set.
Make sure the ScreenPlay Director is connected to power and turned on.
Make sure you have selected the correct video input on your TV to display output from the ScreenPlay Director.
The video output setting on the ScreenPlay might not be correct for your TV. Press the TV SYS button on the remote control repeatedly until the screen displays normally.
Try on a different TV, you TV may not be supported with this device.
Posted on Nov 05, 2010
  • alanhj Sep 05, 2011
    As usual I had the video/sound cable connected to the bottom 3 connectors on the back. I turned on the unit and kept pressing the TV SYS button on the remote a bunch of times (about 30) and nothing. I then moved the cable yellow video connector to the upper yellow video connector on the back of the ScreenPlay and SUCCESS. For some reason the lower video connection still doesn't work. Oh well, as long as it is working I will stop messing with it. THANK YOU! I thought I my ScreenPlay was dead and I would have to send more money on another player. YOU DA MAN!
I HAVE THE IOMEGA SCREENPLAY DIRECTOR EDITION CONNECTED TO A MITSUBISHI 73" DLP TV THROUGH HDMI AND ALL I GET IS A BLACK SCREEN NO MENU
Try another HDMI port. Also, you may wanna try to switch the TV-set to various resolution-modes to see if the device 'likes' it better and sees it first.
Dec 26, 2012 | Iomega ScreenPlay TV Link Director
How i can watch the videos in the TV in colour is only black and white
If the videos are recorded in black and white your out of luck. If your trying to watch videos recorded in color on a black and white tv, get a color tv.
Comment if you need additional assistance or to provide more info.
Aug 05, 2011 | Iomega ScreenPlay Director 1TB HD Media...
I got a windows 7 - 64 bit. the screenplay director hd media player from iomega doesn't show up when connected via usb. what should i do?
Quoted from Iomegas website
When connecting a ScreenPlay to the USB port on a computer, you should always power down the ScreenPlay first, then connect the USB cable and turn power back on. This changes the ScreenPlay from video mode that allows it to communicate with a TV set to USB mode that allows it to communicate with a computer.
When you want to reconnect the ScreenPlay to a TV, use the safe removal process for your operating system to unmount the drive, then power down the ScreenPlay and disconnect the USB cable. Turn power back on after the ScreenPlay is correctly connected to the audio/video connection on the TV set.
To ensure that the ScreenPlay is correctly recognized, do not connect a ScreenPlay to USB and a TV set at the same time.
Do the above and your screenplay director will be recognised by your pc
Please vote for me if you found this info useful
Apr 22, 2011 | Computers & Internet
How do i connect my iomega screnplay director for the first time?
First Time Setup: 1. Connect the power supply to the ScreenPlay Director and an uninterruptible power supply (UPS) or power outlet. 2. Press the power button on the front of the ScreenPlay Director to turn it on. 3. Turn on your TV and change the input setting as needed to receive input from the ScreenPlay Director. 4. When the ScreenPlay Director setup wizard appears on the TV screen, select your language and the TV screen aspect ratio, then configure your network connection. Refer to the user's manual if you need additional instructions. NOTE: If you wish to skip the network configuration during first time setup, you can add it at a later time using Settings from the ScreenPlay Director home menu. See the user's manual for detailed instructions. ----------------------------------------------------------------------------------------------------------------------------------------- If you need any other information about your device, I would suggest looking at the user's manual as it will pretty much answer any other questions you have about your device. Click on the blue links below. ScreenPlay® Director HD Media Player User's Manual: View Online [HTML] ' Download [1.0MB zipped HTML]
Quick Start Guide [PDF 1.2MB]
Specifications
Dec 23, 2010 | Iomega ScreenPlay Director HD Media Player...
I formatted the screenplay director hd drive and just have a screen saying :sleeping waiting for usb keys:
ScreenPlay Director Partitions
There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files.
The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection.
The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface.
Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
************************************CAUTION!************************************************ Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
Conclusion: If you have deleted or formatted any of the first 4 partitions on the unit that is not the data partition. You now own a BRICKED ScreenPlay which HAS to be replaced. No if ands or buts about it. YOUR DEVICE IS DEAD.
Dec 19, 2010 | Iomega ScreenPlay
I have accidentally formatted the default partitions
*******************************************CAUTION!*********************************************************
Oct 09, 2010 | Iomega ScreenPlay
How can I format my Screenplay Director?
Formatting the Data Partition
The data partition on the ScreenPlay Director is formatted with an NTFS file system and will appear as a read-only volume under Mac OS X unless special software is installed on the Mac. If you need to transfer files to the ScreenPlay Director by direct USB connection on a Mac, you must reformat the data partition to FAT32 (see instructions below).
NOTE: On a network connection, Mac OS will see the ScreenPlay Director as a shared SMB volume. This means you can use the network to copy files from a Mac to the ScreenPlay Director without changing the format from NTFS to FAT32. (Recommended if available.)
If you reformat the ScreenPlay Director data partition for use with a Windows PC, it is recommended that you use the Windows format utility to reformat with NTFS. Right click on the drive letter for the data partition and select Format.
CAUTION!
  • Do NOT change the partitioning on the ScreenPlay Director as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition can be viewed or played on a TV.
  • Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
May 19, 2010 | Iomega ScreenPlay
I deleted some of the partitions and now the
ScreenPlay Director Partitions There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files. The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection. The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface. Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
*******************************************CAUTION!********************************************************* Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
May 06, 2010 | Iomega ScreenPlay
I have bought a IOmega Screenplay Pro 1 TB. I was able to see some partition in the HD. Accidentally all these partition were removed. So i need to create those partitions and the size details of each...
Feb 22, 2010 | Iomega ScreenPlay
No matter what type of disc I insert, including store bought movies...player says ''does not recognize disc''
Mar 15, 2009 | Televison & Video
Open Questions:
Iomega ScreenPlay Pro MP3 Player Logo
536 people viewed this question
Top Iomega Audio Players & Recorders Experts
GreatAbyss
Tom Chichester
Nanny
Are you an Iomega Audio Player and Recorder Expert? Answer questions, earn points and help others
