Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Hi,i have a ZDT6053 but it will not heat the water,any sollutions
Posted by 6at6 on
D. Floyd Kolb
  • Zanussi Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 27, 2010
  • p7000 Nov 14, 2010
    Currently on a 3rd heating element for my ZDT 6053. Replacement part is around £40, fitting it yourself is a real pain as you virtually have to dismantle the entire machine to gain access. Put aside a good 3 hours for your first go.
Zanussi zdt6053
Something wrong with Brake System of your Dishwasher. Contact Authorized Customer Service Center.
Mar 29, 2014 | Dishwashers
My pulsar220f is getting engine heat very soon how to send me sollution
Hi Abhi8055 and the usual suspects are:
1. Insufficient oil supply, or oil not circulating.
2. Insufficient air passing over the engine.
3. Heavy carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, O2, and/or CMP sensors.
5. Leaking intake or exhaust valve.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Service Manual Bajaj Pulsar 220
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 17, 2011 | 2011 Bajaj Pulsar 180
Doesn't heat or dry
Hi! jroqqow
The simpilest sollution may be one of the breakers is tripped, if its a electric dryer. If its Natural Gas or Propane, it could become even more complex. Best to check the dryer vent and make sure there is adaquate air flow out this vent. Let me know some clarification, Model Name, Number, electric, gas?
InMrFixIt
Jun 19, 2011 | Frigidaire Dryers
The water has not drained away in my ZDT6053, I have removed filters but the water still wont drain away !
hi you need to open up washer and clean out the filter on the bottom shelve also try and wriggle rthe hose pipe going in at back turn off power and restart
Jan 01, 2010 | Zanussi Dishwashers
Smart chip not working on touch
hi in my nokia 3110 the micro chip are not showing in phone ,
so pls give me sollution
Jun 08, 2009 | LG Vu CU920 Cellular Phone
I brought a Zanussi ZDT6053 integrated. - Fixed in position - buttons light up but does not fill in oor start.
Dearest FixYa,
Thanks ever so much for your prompt response and am ever so grateful for standing to support anyone in problem.
Fortunately, I have solved the problem.
Basically the problem was that the water supply tube would kink when unit was pushed back into its space under the kitchen top. And it was totally difficult to see that problem from he rear of the unit.
Last effort wasto monitor every thing as the unit was showly pushed bak under the kitchen top. This time it was discovered that the water tube happened to be seen clearly from underneath the unit as 'kinked'.
When straightened, the unit simply went 'full in motion, and hey presto it worked straignt away.
Thanks for your 'standing by' to support with an army and great team of 'experts behind you.
Sincere regards
Mar 28, 2008 | Zanussi 23 in. ZDi6053SX Built-in...
Zanussi zdt6053 will not fill with water, on any programme, it appears to try to start and makes a moise as if pumping, but there is not water to drain, and pump appears to operate if water is poured into...
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Jan 15, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
807 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
