Nokia 6600 Logo
Question about Nokia 6600
6600 power switch jumper - Nokia 6600
Posted by lx_bhattarai on
Anonymous
    New Friend:
How to have cellphone
Posted on Oct 25, 2010
Anonymous
    New Friend:
How can i repair my 6600 without the 2 capasitor frome the swits plssssss. help me
Posted on Mar 29, 2011
Anonymous
    New Friend:
Panu po mag jumper sa switch on board po kasipo lobo yung borad sa bandang ibaba ng switch matutulungan po ba ninyo ako thanks
Posted on Mar 27, 2011
1 Related Answer
ashlocked
Christopher Lozada
  • 1140 Answers
SOURCE: 6600 power switch jumper
here buddy
hope it helps...
Posted on Jun 03, 2011
7helpful
2answers
here buddy
hope it helps...
Jun 03, 2011 • Nokia 6600
Nokia 6600: Bluetooth wont open
solution for 6600 bluetooth and gallery cannot open
step 1) make a jumper (you can see the encircle terminal of bluetooth ic) then assemble the mobile,turn it onstep 2) OPEN FIRST THE GALLERY WITHOUT MEMORY CARD,THEN OPEN ALL THE IMAGES,MUSIC ETC. INSIDE OF YOUR GALLERYstep 3) TIME TO TURN ON YOUR BLUETOOTHstep 4) PUT BACK THE MEMORY CARD AND DO 2 AND 3step 5) then remove the jumper and do step 2,3,4..if still the cannot open again,put the jumper and reheat the bluetooth ic and repeat it step 1,2,3,4.I ..GOOD LUCK TO ALL WANT TO TRY! JUST TRY IT THERE IS NO RISk
Mar 17, 2011 • Nokia 6600
1helpful
Power switch diagram
The easy way, use a multitester, set to DC 10v insert your battery than search 1,7 volt from black capacitors under the power on switch.there is two black capacitors,the left one that suplay power 1,7 v. you can put power from it.good luck..if you can'find it you can chatt with me.
Jan 14, 2010 • Nokia 6600
6600 bluetooth and gallary jumper problem a am not eable open the gallary
U have to format your phone to format your phone backup your files to pc using pc suit then switch off your handset then press callling button,*,and 3 together and press switch on button the formating option will apears on screen ,if it does not work then press *#7370# this willl work
Sep 09, 2009 • Nokia 6600
How can i format my nokia 6600 direct
Formatting on your 6600! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6600 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory setting.
2helpful
Switching on 6600 white screen appears again getting switch off
try to format it..
press and hold call button(green button)+ * + 3 and power on button
until formatting letters appear...
May 04, 2009 • Nokia 6600
2answers
Not charging for nokia 1100
good evening ! the problem of your phone is the resistor 100 try to chagne that , that`s located at the mother bord! R100 GOOD LUCK ....
Sep 08, 2008 • Nokia 6600
2answers
Nokia 6600
maybe the switch took off, if power button is not working,, it may have been detached to the board, u may have to check it out or go to a repair shop, to re attached the button
Aug 24, 2008 • Nokia 6600
2answers
6600 camera temp over load
try reformatting your fon... try this... press together call, *, 3 then switch it on and hold all keys until you see formatting on the screen...
remove batt and do it again if formatting doesnt display on screen...
if still nothing happens after formatting then probably you have a prob in your bluetooth module...
Oct 28, 2007 • Nokia 6600
12helpful
8answers
Nokia 6600 joystick
make a jumper w/ a jumper wire joystick #4 to flex #4
skilled technician can performed the jumper'
or replace it w/ new keypad joystick of 66..00
Oct 21, 2007 • Nokia 6600
Top Nokia Cell Phones Experts
Muzahura Frank
Kolbrun...
Marvin
Marvin
