Once your television starts blinking the green light, then it means there is a problem inside the unit.
the problem simply is a bad lamp that is why you are having a black screen.
The solution is simply for you to replace the lamp of the television with a new one. To replace this, you will have to unscrew the television open and try to remove the old lamp and fix in a new one. It is very easy.
If you are still having the blinking light, then it means it is not only the lamp that is faulty, there also is a bad capacitor on either the main panel or the power panel of the television that needs to be replaced.
Once the bad capacitor is replaced, your television will be in good condition once again.
Take care and good luck
