1989 Dodge Omni Radiator
Part Number: 12553SAP0882P
Manufacturer Part Number: w5LDkcOWw5bDkMK7w5PDm8Obw5HCsw==
Part Specifications:
Core Size (in) approx: CU/BR 17-1/4 x 12-1/2 x 1-1/4, 2 ROW
Tank: PLASTIC
Weight: 8
Part Details
2.2L L4 Without Heavy Duty Cooling + Without AC - All Transmission.
This Part Fits:
1983-83 : DODGE OMNI 1.6L L4 98
1984-88 : DODGE OMNI 1.6L L4 98
1984-88 : DODGE OMNI 2.2L L4 135
1989-89 : DODGE OMNI 2.2L L4 135
HOPE IT HELPS
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
SOURCE: need to change radiator fluid
Drive car up on ramps and take off lower radiator hose to drain entire system
SOURCE: radiator fan blown up put hole in radiator need to change both need help with and tools needed
First you have to remove the air intake panel by either the screws or the pushclips on the sides. This then simply lifts up allowing you to gain acces to the radiator fan.
The viscous coupling fan is then held on by what appears to be a large nut coming out the side of the engine. i believe this is a 32mm ad an open ended spanner is the tool for the job. However its on tight so gently tap with a hammer to loosen and able to unscrew by hand. The fan cover/gaurd around the fan is held on again by 2 screws/pushclips on either side and would need to be lifted out with the fan.
When reversing the steps to fit a new one you only need to nip up the fan when tighteneing as the it uses the rotation of the engine to keep the fan tight in place!
Not a difficult job but can be tricky putting the new fan back on the threads!
Hope this helps!
SOURCE: change radiater and heater radiater i dont have taurus 98
Have your heater core flushed. Works like a charm every winter when I do it.
SOURCE: need to change coolent in radiater
You don't need to use a special kind of radiator flush, but the coolant is called DEX COOL. It's made by prestone specifically for GM engines, you can get it at walmart for like 5 bucks.
