Question about Samsung HL-S4266W 42" HDTV
I have a Samsung HL-S4266w TV When I plug in tv I get no picture and A sqealing noise. 1st the lamp led flashes 2nd stand by temp led comes on 3rd lamp flashes 4th all three led's flash (timer,lamp,and stand by temp) I tried an original manufactured replacement lamp no help. I also held the back light switch in no help. Does this problem sound like a color wheel
Posted by jaap670 on
ladywinn
  • Samsung Master
  • 5,138 Answers
You need to replace the Color Wheel.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-844-7871
Posted on Oct 25, 2010
Samsung hlc4266w says replace lamp after lamp replacement
The set may have a lamp timer built in and the owner manual will explain how with the remote resetting that.
Sep 05, 2012 | Samsung HL-S4266W 42" HDTV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Tv comes on for about 10-15 seconds then shuts off and all the lights in the front blink (lamp,temp,and standby)
You have a power supply circuit issue.
Possibly a component in the primary side of the power regulating circuit for power on is weak or defective.
You unit will require a tech to look at the power section of your TV.
Mar 19, 2010 | Samsung HL-S4266W 42" HDTV
Tv wont stay on
Have you checked the lamp? If the tyv is 3 years old and the lamp has never been replaced,it's time.The crackling noise also sounds like a blown lamp.
May 10, 2009 | Samsung HL-S4266W 42" HDTV
Samsung hlp 5063w humming noise
Can you reseat the lamp?  Don't forget to unplug the TV of course, but sometimes the connection between the lamp and TV degrade due to heat contraction and cooling.  Some TV's provide an error code by having LED's flash a certain way, is this what you mean by lights flashing?
Mar 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HL-S4266W 42" HDTV Logo
433 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
