Will Printmaster Platinum 16 run on windows 7 I don't want to install if it is going to give me a problem
Printmaster Platinum 16 is not compatible with Vista or windows 7.
PRINTMASTER 16 does work with both Windows Vista
I switched from XP to vista and have had problems ever since. To save to PDF file in pm platinum 16I get the following messages (1) Error opening hklm with all access setting up the registry. (2) Error attempting to open with write access one or more configuration files for hashing, (3) PDF converter unable to initialize the pdf printer driver.
Actually it IS compatible - I am using it on Windows 7 atm. What is not compatible, is the pdf converter - a problem which can be gotten around by using cute PDF.
If it is really compatible ie. all the plug-ins should work without using another third party software for a workaround? Anyway good suggestion for the workaround.
Has anyone launched Windows XP Virtual PC and installed version 16 in the virtual PC? Do yo have full functionality under Windows XP Virtual PC?
