SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
SOURCE: GE ice maker
I carry this ice maker on my truck and they are supposed to come with a universal cup so it could be mounted either way. See if you can pull off the cup of the old one and switch it to the new one. If not have them send you another ice maker because that one is not right.
SOURCE: Jenn-Air JCD2389GES problems
The condensor fan cools the condensor coils. If it is running this will cause a no cool situation. Also, if the condensor coils are plugged with dirt that insulates the coils and causes a no cool situation. These things will make it so the freezer isn't cold enough to freeze water so the icemaker will not produce ice. As far as the door edges getting hot. A condensor line runs thru the cabinet between the doors and this is called the mullion. If it is too hot this is a good indication of a bad condensor motor or dirty coils. Clean the coils and check the status of the fan motor and let me know what you find and we will see if we need to go further.
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Hello - If your ice maker has stopped producing ice completely, try checking the following:
· It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
· Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
· When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
· Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact a professional to move forward accurately.
Hello anjcarr - If your ice maker has stopped producing ice completely, you can try checking the following:
If any proves to be ineffective, contact a professional to move forward accurately.
