My maytag dryer was working good.
today it a no go timmer sounds like it is working. have power to timmer.
found the breaker was off turned on and power good to dryer.
door switch feels good.
it is a maytag pye/g2300,3300
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Hopefully you still have your manual-if not dwn load this one and go to page 23 Download 20W10150608A.pdf initiated.
If download did not start, click here to try again.
sounds to me that something got loose during transportation. check if some wire got loose like a door switch wire. looking at the picture looks like you have a device at the motor called a condensor/br. the /br part look like a breaker. you may have to take the dryer apart and hunt for a disconnected wires. good luck to you. let me know what you find.
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Hi there, you are experiencing a power supply board failure. this board may have used all its life up and unfortunately, it will have to be rebuilt or replaced.
