Your phone memory is full... if you are transfering huge file then it won't be accpted...i recomande you to go
menu>>message>>option>>setting>>other>>memory in use...
try to change it from 'phone memory' to your 'memory card'..
it will ask u to copy the new msg to memory, so press yes and yes for to save the original message.
all ur message will be copied to the memory card...now you can recieve more file depending on the memory available in your memory card.
There is still a problem here!!!! When you will connect your mobile to a pc it will say "unable to activate data transfer mode ...bla bla bla...." so you will have to change memory in use option everytime to phone memory then try to connect it to ur pc...
thanks.. regard from Nireshis
