It seems that the timer is faulty and must be checked on for loss of contact while it is in the spin mode of the cycle. It can be a mechanical failure of the connections or a possible failure of the contacts.
It will be good if you can source one timer unit to be set on for a trial swap so as to confirm before you can invest on one .... being expensive.
Hi Rylee
Thanks for using FixYa. To start with check the lid switch, you can also
try to jump it to check if that is fine. If the lid switch is fine then it is
the Motor Control going bad and should be replaced. Please accept the
solution if the issue is resolved or post a comment for further
assistance.
Thanks
So I checked the lid switch and it's working fine, we also emtied the washer complitely and took off the hose for the OPR pressure switch than put it back on (in case that the OPR switch was stuck in wrong position form the moving in the new house). The washer got better - filled with water all the way and mutates, but after it filled the water now it's stuck on 38min(44min normal wash) and just keeps nutating and recirculating the water :(
Think we are one step closer to discovering the secret of longlasting Calypso washer :)
But now what next?
I thought about the timer,but the problem is that the cycle gets stuck before it gets to spin, it counts down maybe 3-6 min and that just gets stuck on one action. I don't know which circuit board is most likely to be responsible for that - machine or motor board?
