SOURCE: Can't turn off the CC on my TV
Does your set have menu on front of tv if so press menu use your channel up & down bottons to move up&down menu go to video use your vol up & down to adjust set to off on cc. Also need remote go to Dollar store buy RCA 4 in one remote 5.00 works all tvs has code book with it your code probly 062.
SOURCE: cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
SOURCE: Turning off the closed captioning without the remote.
I had the same problem. I got a Philips Magnavox Universal Remote that has a closed captioning button [CC]. Here's a link to the same type:
http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1240350929&sr=8-1
SOURCE: Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
