Question about Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 touch screen dosen't work - Garmin Nuvi 660 GPS Receiver
Posted by fullhouse7l on
perdue40
  • Garmin Master
  • 589 Answers
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Posted on Oct 24, 2010
  • thory Dec 28, 2010
    Your advice was the perfect solution. No one else could help me. Excellent work, thank you, thank you.
  • garman4983 May 11, 2011
    i have been pressing dot for about 30 minutes as it moves around screen. How long must I do this?
4 Related Answers
Anonymous
  • 4090 Answers
SOURCE: touch screen on my Garmin Nuvi 660 just stopped functioning
If after a calibration the screen fails to respond then its the scrapheap i am afraid The cost of fix exceeds the value to replace
You could try a claim on insurance to have it replaced, especially if it was accidently dropped
Posted on Jul 26, 2009
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: touch screen won't respond
The touchscreen needs replaced. Please see this link for more information.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Nov 13, 2009
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: Garmin nuvi 660 touch screen froze? How to fix?
please see this link. read about non-responsive touchscreens.
- Jim
Posted on May 12, 2010
perdue40
  • 589 Answers
SOURCE: i have a garmin nuvi 660. the touch screen isn't
  3. Touch Display.
Nuvi 660 screen locked
I HAVE THE 205 UNIT MY LOCK IS ON THE POWER BUTTON SLIDE IT TO THE RIGHT IT LOCKS AND PUT IT IN CENTER TO UNLOCK - YOURS SHOULD BE CLOSE TO THAT - HOPE IT HELPS
7helpful
4answers
Not touch sensative
In 90% of the cases it's the digitizer (the touch sensor that is mounted in front of the screen). You can try to replace it yourself or send it to a third party gps repair service.
Cracked screen
The only way to repair it is to send it to Garmin for service. They recently told me the flat rate to repair my streetpilot 550c was $250. (!)
10helpful
3answers
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
5helpful
4answers
Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Garmin Nuvi 660 GPS Receiver Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
'Victor Collazo
'Victor Collazo
Are you a Garmin GPS Expert? Answer questions, earn points and help others
