Computers & Internet Logo
Question about Dell Inspiron 3800 Celeron 500MHZ Processor (CPU) - 569KW
When istart my computer it starts to boot then stops then continues to repeat this cuycle over and over
Posted by wilks_ray on
Brian Sullivan
  • Dell Master
  • 27,725 Answers
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Posted on Oct 23, 2010
2answers
Chrome menu settings
we have chrome istart loaded and there are 2 ways to access your volume settings:
1. minimize the chrome window
2. use the chrome istart setting to adjust/add the volume setting.
if you still have issues please email us!
Computer keeps trying to reboot continuously
overheating?
did you do any hardware upgrade befor this problem?
I HAVE NO NEW XP WINDOWS RECOVERY CD FOR MY MEDION MIM2220 SO I CANT START WINDOWS , WHEN I TRY TO INSTALL FROM RESTART IT COME WITH THIS MESSAGE WHILE TRYING TO BOOT ( AN ERROR HAS BEEN ENCOUNTED THAT...
Do you have the original installation disk that came with the computer? You can try to boot from that CD and do a repair installation. The Cyclic Redundance Check (CRC) error refers to the media the computer is trying to access (either the CD or the hard drive). Try booting into Safe Mode (reboot and press F8 repeatedly until you get a boot menu). From Safe Mode run a checkdisk (chkdsk from command line) on the hard drive to find and repair any found disk issues.
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Computer when i turned it on said disk read erroe occured and now when i try to start it in safe mode it just keeps restatring it self
Start up your computer.
Immediately insert your Windows XP install CD. As the computer boots, a boot menu will appear (if you did not insert the CD in time, you will not see the menu; in this event, simply reboot the computer again).
Select the option to boot from the CD. A setup screen will soon appear.
Press the "R" button on your keyboard at the setup screen in order to open the repair console.
5
Type in the administrator account's log in password if you are prompted to do so. If there is no log in password, simply leave the password slot blank and continue. After this step, a command prompt will appear.
6
Type in "chkdsk" (minus the quotation marks) and press "Enter." Allow the operation to run.
7
Type "Exit" (again, minus the quotation marks) when the operation is complete, and press "Enter." If your computer boots correctly, great! If not, move on to the next step.
8
Reboot and repeat Steps 3 through 5.
9
Type "fixboot" (minus the quotation marks) and press "Enter." Once it is complete, repeat Steps 7 to 8.
10
You might need to reinstall your operating system.
Thanks.
Before it starts fully the computer starts then stops starts then stops again then finally starts and boots correctly
Do you mean powers down and then on agan or boots windows fails and then restarts?
If it's powering down then it usually means you either need a BIOS upgrade so check the DELL website or your computer needs internal cleaning as the dust is causing issues.
If it's restarting from windows then hit f8 repeatedly when you see the windows logo and select safe mode with command prompt at the command prompt type:
sfc /scannow
and hit enter.
None stop Continue long beep, fan slow little while and start normal repeatedly
What's this start normal repeatedly thing, you mean after a while it starts the boot process again, and you never get a BIOS screen?
You probably overheated things.  Test everything in isolation if possible, otherwise just inspect and reseat RAM, the videocard, the CPU, and try again.  When it happened to me last I had a burnt-out videocard.
2answers
Unable to boot up
1. Reboot your computer.
2. Press F8 repeatedly on the very first screen you'll see after turning the system on.
3. Select "Repair Your Computer"
4. Hit Next on the keyboard layout
5. Select your account name and enter password
6. On the Recovery Options, select Startup Repair
If that doesn't resolve the issue:
Repeat steps 1-5 above. Then select System Restore instead. Restore the system back to a date where you think it was working fine.
2answers
Acer Laptop keyboard problem
It sounds like you have a problem with your CMOS battery. I had a similar problem with another Notebook recently. The computer does not know its CMOS settings (including the BIOS settings) anymore since the battery is empty or damaged. When you enter the device selection (F12) it saves the information again so it can boot normaly now. I think you should get a new CMOS battery and the problem might be solved. Also the keyboard problem might be fixed with that - i also had keyboard problems with the Laptop i mentioned above when the battery was empty.
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
