Poulan Pro 22" Self Propelled High Wheel Mower Logo
Posted on Jul 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I engage the blades on my 54 inch Poulan EX 700, the motor shuts off. I have changed the spark plugs, changed the air filter and the fuel filter and it is still happening. I bought the mower from Badcock's after it had been returned for nonpayment to them (the original owner only had it 2 months) and got no manual with it so I can't troubleshoot or even find out where the parts are in the engine. Some help would be appreciated.
jhnolson
Level 3:
  • Master 822 Answers
  • Posted on Jul 03, 2017
jhnolson
Master
Level 3:
Answers
822
Questions
Helped
292556
Points
5434
This is a common problem. The driver must be in the seat when the PTO blades are engaged.
Below the seat, attached to the seat there is a switch that confirms the operator is present.
If the switch is defective or seat is obstructed the switch wil not actuate and the mower will shut off.
Hope this helps?
5 Related Answers
studio500
Marc Buck
  • 36 Answers
  • Posted on Apr 17, 2009
SOURCE: I have a POULAN lawn mower that has sit unused for
Ensure that you refill it with new fresh fuel not the fuel that was left inside it as fuel does has a limited life.
Regards
Marc
Anonymous
  • 109 Answers
  • Posted on Apr 21, 2009
SOURCE: locked blade - poulan push mower
Check the oil level in the engine...if the blade is locked up, so is the engine, sorry
Anonymous
  • 109 Answers
  • Posted on Apr 26, 2009
SOURCE: poulan 21
Try putting a SMALL amount of gas in the carb and see if it will start, if it does, it is a fuel problem, if it does not it is probably an electrical one
Bob S
  • 15 Answers
  • Posted on Sep 27, 2009
SOURCE: Poulan pro 20hp 42" lawn mower running rough
My immediate impression is that the float is "stuck open".
Pull the float-bowl, and check that:
a. the bowl and float are clean, and
b. the float moves freely, and
c. when it's in the "up" position, the flow of gas stops (which means that the needle is "seating" properly and doing its job)
rwvanlue
Roland W VanLue
  • 486 Answers
  • Posted on Nov 22, 2009
SOURCE: Poulan Pro Mode 96134000800 push mower dies immediately
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
2answers
Kawasaki engine on Husqvarna p-zt 54 loses power when blades engage
There are a few potential reasons why your Kawasaki engine on your Husqvarna P-ZT 54 may be losing power when the blades engage. Here are a few possible causes and solutions:
Low engine speed: If the engine speed is too low, it may not be able to power the blades effectively. Try increasing the engine speed by adjusting the throttle.
Dull blades: Dull blades can put extra strain on the engine, causing it to lose power when the blades engage. Sharpen or replace the blades as necessary.
Belt tension: If the belt that drives the blades is loose or worn, it may slip when the blades engage, causing the engine to lose power. Check the belt tension and replace the belt if necessary.
Dirty air filter: A dirty air filter can restrict the airflow to the engine, causing it to lose power. Check and clean or replace the air filter as necessary.
Fuel issues: If the engine is not getting enough fuel, it may lose power when the blades engage. Check the fuel filter and make sure the fuel tank is clean and free of debris.
If none of these solutions work, it may be best to have a professional mechanic take a look at your mower to diagnose and fix the problem.
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Poulan HD145H42H stalls after a little while of mowing. When I re-start it will start at idle throttle then stalls again when I throttle up or engage the blades. Any ideas?
Hi John:
Have you checked the basic maintenance items?
- Air filter
- Fuel filter
- Fresh fuel
- Oil level
- Spark plug condition
- Clogged underside of cutting deck
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 • Garden
1helpful
2answers
Why does engine speed decrease when blades are engaged?
need to clean grass from under mower change plug and air filter for better perfomance
Jun 15, 2012 • Garden
1helpful
John Deere 17 horsepower Kawasaki engine won't run WOT when blades are engaded
swap the coil with the other side and see if that plug gets sooty instead of the one that has been
May 27, 2012 • Garden
Engine running issues
strip and clean carb check float,then run fuel system cleaner through the tank and you should be away
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
