Pioneer DEH-P3000 CD Player Logo
Question about Pioneer DEH-P3000 CD Player
DEH-p3000 wiring diagram, I want to make a work bench radio I have 12v dc power and 4 speakers
Posted by robertalacha on
5 Related Answers
Anonymous
SOURCE: wiring diagram pioneer deh-3400
ce3d034.jpgh
ihave this for you
Posted on Feb 06, 2009
Shdak
Mike Abrams
  • 23 Answers
SOURCE: what is the speaker wire color code for pioneer
Crutchfield has allot of information on Pioneer receivers. They also have a number you can call for support. The wiring diagram can be found here: PDF File
Posted on Apr 06, 2009
Anonymous
SOURCE: Need wireing diagram for DEH-1600
  • Gray - Front Right +
  • Gray w/Black Stripe - Front Right -
  • White - Front Left +
  • White w/Black Stripe - Front Left -
  • Purple - Rear Right +
  • Purple w/Black Stripe - Rear Right -
  • Green - Rear Left +
  • Green w/Black Stripe - Rear Left -
  • Blue w/White Stripe - System Remote Control (Ant)
  • Black - Ground
  • Red - Switched Power
  • Yellow - Always On Power
The Pioneer DEH-16 is the same as the 1600. The only difference is the faceplate and LEDs. It can be found at the Pioneer website.
Posted on Aug 14, 2009
Anonymous
  • 85 Answers
SOURCE: Wiring diagram for Pioneer DEH-P6550
black is negative blue is remote red is accesory key switch yellow is constant power memory,gray with black is RF negative and gray is positive white is LF positive and white black is LF negative.violet is RR positive and violet black is negative and green is LR positive and green black is negative
Posted on Sep 14, 2009
Anonymous
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
1helpful
How can I find a wiring diagram
Hi Bob
Not much info to go on??
Usually don't need one
12v DC to posative (red)
12v Ground to Chassis or body of Amp
Possibly an Ignition Key 12v to hold memory settings
2 Speaker Unit will have 4 wires - 2 to each speaker
one wire of each pair will have a stripe (say negative)
keep striped wire to same speaker terminals to keep the speakers in phase with each other (speaker cones travel in same direction or you get distortion)
4 Speaker Unit - same as above but either Front Pair or Rear Pair.
Get the Amp on a bench & test the unit with a couple of cheap temporary speakers.
Good Luck
How to connect your car amplifier very simple explination and test
Part 1 How To Set Up PSU Car Amp Subwoofer In Home Re Do Video
I need a wiring diagram for the rear plug. I have the unit powered up by using the yellow wire to 12v and the red to a 12, switched source, and the black to ground. I can't get any sound? I have the...
please email me at [email protected] and i will get a manual to you. Thank you.
FixYa Support
Please accept solution by rating 4 thumbs up and leaving feedback and comments. Thank you.
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
2answers
We have a DEH-6 pioneer radio that we are trying to install in the 1994 dodge caravan.We cannot find where to hook the white wire from the radio. when you turn the ignition on the radio lights up but the...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
2helpful
Pioneer deh-p3000 when i turn the key off and back on the stereo's doesnt remember anything
did you wire the radio yourself? it sounds like you have the yellow wire connected to a switched power source. the yellow wire needs to go to a power source which is always hot, or constant, whether the key is on or not.
Need wiring diagrams from a 1994 chevy s10 to a pioneer deh-p3000
its not a big problem try another speaker from the right side. if not work. check fuse and the wire. just follow the wire where its connected. if no fuse found. the problem is in the amplifier IC. change it if speaker from right side is not burned yet. thanks.
Wiring diagram
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
35helpful
6answers
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Reconnecting Deh - P3000
HI. search pioneer no sound on this board. i have already walked another guy through this... if everythng works but no sound is outputted.. 99 times out of 100 the audio output ic "chip" is bad. Its a common failure for pioneer cd players as well as others. The part is about $20 if you know where to look... if you decide to repair this yourself you will need to be very skilled with solder and desoldering braid... let me know
6helpful
Wiring schedule for 2002 new beetle volkswagen radio
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
