SOURCE: Amana French Door Bottom Freezer Refrigerator making noise but not making ice
The noise you hear is the ice maker trying to make ice without a water supply. Check the line to make sure you didn't knock anything loose or kink it when changing the filter, and check for a plugged line. It could be that there is ice build up in the line, a defrost will cure that.
SOURCE: Have Amana refrig with bottom
See the post by lola77 with the same complaint. We have an Amana top/bottom freezer and are having the same problem and we've only had it 4 1/2 years. First service call available that the 1-800 number gave me was 3 days from now, which is ridiculous.
SOURCE: Amana fridge door on wrong side
Generally, doors can be swapped side to side. Look for some kind of plate where the hinges would be on the other side of the box from where you've got the door mounted now. It may be covered with a plastic piece. If you find it, you're in business. A small socket set is all it usually takes. Get help holding the door in position as you do the work. Doors are heavy.
SOURCE: Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
[email protected]
SOURCE: Amana bottom freezer not working on model abb2524deq
I replaced the solenoid and my ice machine starting working again.
