Compaq AlphaServer DS10 Logo
Question about Compaq AlphaServer DS10
Compaq Alphaserver DS10, when powered up, fan & environment led glows & it shuts down after 30 seconds. i have replaed all 3 fans. they are of same voltage rating i.e.12V but current rating are lower then orignal fans.... all 3 new fans are working ok but still problem is same......any suggestion plz....
Posted by indiantechno on
4 Related Answers
Anonymous
  • 6 Answers
SOURCE: No display
hi sucb Clear nvram and replace memory then checked it will work. there is one black button on system board plz locate it and by pressing it put power on after the display comes update the firmware and bios. pls be free for any assist thanks
Posted on Sep 06, 2007
Siul Oyaratgam
  • 317 Answers
SOURCE: ALPHA SERVER DS10 with OPEN VMS 7.3
check the computer memory Ram and the processor
Posted on Mar 07, 2008
Anonymous
  • 4234 Answers
SOURCE: DS10 with SBS PCI Expansion
Version 7.1-2 is an older version of the OS. I will have to check, but I think that V7.2 will resolve this. What version of TCP/IP are you using? Back in the day when I supported TCP and VMS, there were some timing issues that causes odd behavior. If you can provide the details about your configuration, I can check and get back to you. If necessary, an examination of a forced crashdump may be needed.
A rare opportunity to work with VMS again!!
Good stuff.
Dan
Posted on Aug 01, 2008
Anonymous
SOURCE: DS10L AlphaServer CPU Fan Failure
The answer is to get hold of a high-speed case fan. I used a Scythe s-flex 80mm which has a +/- 5% RPM of 2800. rearrange the pins or use a choc-block such that yellow -> black, red -> yellow, black -> red. Hey presto.
Works for me.
Posted on Jul 04, 2010
How many OS supporting alphaserver ds10
HP Open VMS, HP Tru64 Unix, Linux, MS Windows
IP address change needed on a AlphaServer DS10
First, identify the NIC you wish to change; use:
$ MC LANCP <ret>
> SHOW DEVICE
Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc:
$ @TCPIP$CONFIG <ret>
Option 1 - core environment
Option 2 - Interfaces (then select your NIC or the IP Addr to change)
Option 2 - add/change a Primary address on *** (where *** is your NIC).
2answers
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
2answers
HOW TO GO TO BIOS SCREEN
I am not very familiar with Alpha. Do either of these manuals help? Here is a Console Reference and a Console Firmware guide that talks about it.
Thanks
Good stuff.
Dan
Works for me.
2answers
Ds10 problems
You need to get its BIOS updated manually. Good Luck.
No display
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Marvin
Marvin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
