Panasonic DMR-ES25 DVD Recorder Logo
Anonymous Posted on Jan 02, 2018
My 3 year old Panasonic VCR (DMR ES20) is still stuck at 000000 after a power outage. I have unplugged it, it says Hello but it won't open. If I press on Power for a few seconds, the blinking time shows up and after 10 seconds it reverts back to "hello". Any suggestions would be much appreciated.
Jean DeLauche
Level 3:
  • Panasonic Master 2,911 Answers
  • Posted on Jan 02, 2018
Jean DeLauche
Panasonic Master
Level 3:
Answers
2911
Questions
Helped
974346
Points
13029
Hello, Ejband -
I believe your Panasonic DMR ES20 is a DVR (Digital Video Recorder) and not a VCR (Video Cassette Recorder.)
If you do not have the user manual for your DVR, you can find it here to download for free:
http://tv.manualsonline.com/manuals/mfg/panasonic/dmres20.html
It is a PDF document, so you will need Adobe Reader software (free).
I suggest you run through the set up procedures for your DVR, just as if it is a new installation. Among other steps you will need to reset the time (reset the clock.)
Wilson F.
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 30, 2020
Wilson F.
Contributor
Level 1:
Answers
Questions
0
Helped
938
Points
Hello
I would like to help owners of DMR-ES20 to fix the known "zero" error. This occur due a failure on PSU section that can't provide correct voltages to other modules.
Is recommended replace 7 electrolytic capacitors (Cap Kit) with 105°C range.
C1143 100uF 350V
C1150 56uF 35V
C1280 680uF 10V
C1400 470uf 16V
C1270 1000uf 16V
C1260 1500uF 10V
C1281 47uF 25V
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 25, 2007
SOURCE: dvd recorder panasonic dmr-es20
run cable box through dvd recorder
A
Anonymous
  • Posted on Nov 22, 2007
SOURCE: Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Cameron Scott
  • 105 Answers
  • Posted on May 03, 2008
SOURCE: Looking for the regional code
Region codes are preset in the DVD unit. DVDs are encoded with a region code and are only playable if the DVD player is programmed with the same code as the DVD itself. If you want to play Australian DVDs, you will want to use code 4. There are 9 codes. Check below to find out what region each code is for:
http://en.wikipedia.org/wiki/DVD_region_code
You usually may only change a region code 3 times before it becomes permanent. You need to enter the menu-setup options in your DVD player and you'll want to look for "region code".
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Dec 16, 2008
SOURCE: How do I find an owners manual for my Panasonic DMR-ES30VS?
Unless the "S" is for Spanish (also available on Panasonic's website), the link to the manual is here:
http://service.us.panasonic.com/OPERMANPDF/DMRES30V.PDF
-Tha Mp3 Doctor
Anonymous
  • Posted on Jul 25, 2009
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
On the Panasonic DMR-EZ47V, it had a VCR tape stuck in it, when turn on shows, F60, now doesn't show anything.
Yes bad caps on the video processing board according to the links
SOLVED: F60 error on Panasonic DVD recorder - VCR
iFixit https://www.ifixit.com > Answers > View > F60+error...
Oct 8, 2014 - Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board ...
I have a DMR EZ485 that shows an error code of F60. What
JustAnswer https://www.justanswer.com > Electronics Question
Jan 5, 2018 - The F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ...
1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Panasonic DMR-ES40V Drive and F60 Code
AVS Forum https://www.avsforum.com > threads > panasonic-dmr...
Oct 26, 2014 - F60 is a result of a low or missing voltage on the digital board. Often the culprit would be capacitors that have leaked. But first try a "cold ...
Another Capacitor Failure, Another Fix
EE Times https://www.eetimes.com > another-capacitor-failure-a...
Jan 21, 2019 - An online search revealed that F60 was a general failure code, usually caused by a failed aluminum electrolytic capacitor. Time to get the ...
Picked up a Panasonic DMR-EZ475V that throws a code ...
Reddit · r/VHS 2 comments · 2 years ago The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
My Panasonic DMR-ES40V DVD/VHS player now says " ...
JustAnswer https://www.justanswer.com > recorders-and-players
Dec 23, 2012 - F60 is a general error code indicating a failure on the video processing board. First try a "cold boot". Unplug the recorder again, allow it to ...
2answers
Panasonic dmr es20 frozen
Hello
Unplug the DMR from AC mains socket, and replug it after 5 minutes. If this does not help you, make a factory reset to this set. Get into the user manual, and there is proceedings how to do the factory reset.
Panasonic DMR-ES20 no longer plays back picture on any DVD. Sound works fine, but no picture. Have tried with component, S-Video and RYG cables, but no picture.
I just had the same problem, Tried a bunch of things, ended up just unplugging it, letting it sit for a min and plugged it back in...fixed.
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
7helpful
Cannot unlock ratings on my Panasonic DMR-ES20!
Apparently it is caused by power outages.
Here's the fix: Put in DVD mode.
• While the disc tray is open, press and hold [* REC] and [PLAY/x1.3] on the main unit at the same time for 5 or more seconds. Press until you see INIT on front screen of unit.
2answers
DVD Recorder keeps getting stuck at "HELLO"
Try going through the menu, and locate update system, do that then when its finished cancel the auto look for updates.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
