SOURCE: TV will suddenly change channels, change volume, or go to set up screen by itself
yes and this is a common problem! First lets check out the obvious/ when theis fault starts to happen take out the batteries out of the remote control. If the problem stops then you need a new remote. If the proplem persist the remote sensor assy is bad in the tv set. Ive never heard a cable box causeing a motherboard to act up?? Wait arent mother boards in computers?? lol. believe me you need to tell the tv msn to replace the rmote sensor. Now in an extremly rare cases the microprocessor was causing the problem BUT highly unlikly. Good Luck
SOURCE: HDMI Input Failed
I've been seeing alot of this out in the field. The cable is thick and heavy, after awhile the HDMI connectiion inside the set comes apart and breaks from the main board. In my opinion the only difference between Component jacks and HDMI inputs is the thought of reducing the amount of wire mass in the back of the unit. It's more pleasing to the eye. If it's under any kind of warranty, call a servicer. The main PCB will need to be replaced. If it's not under warranty, use component input cables, you'll get the same performance from your set and save a few bucks.
SOURCE: Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
SOURCE: No picture Thin line across middle of screen
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: picture and text extend beyond screen
Your tv needs to be put into service mode with the original Sony remote control and then set the vertical\horizontal size parameter to the correct values and then burn the new settings to memory
Google " sony tv service mode " and you should find the procedure. Good Luck! Write back if you have problems.
barneyluc
