Question about Lands Phones
I have a Comdial Edge 120. When a call is transferred to an extension and is not picked up at that extension within a certain period of time, it goes to that extensions voicemail instead of bouncing back to the person who transferred the call. How do I get it to bounce back to the person who transferred the call in the first place?
Posted by Elizabeth Burton on
Carl Navarro
  • Lands Phones Master
  • 2,460 Answers
I'm not familiar wiht Edge terminology, but the idea is you set the transfer recall time to something less than the call forward to voicemail. It means that any calls to voicemail have to be direct transfers and there may be some auto attendant issues.
HTH
Carl
Posted on Oct 24, 2010
My calls go directly to voicemail on edge 120
Normally when calls go directly go to voicemail, there are a couple things why this happens:
- Extension are unavailable/busy
- Call forwarding/Do Not Disturb are on.
If you do have call forwarding/Do Not Disturb on, please consult your user's manual for detail instructions since there are several options for call forwarding (Forward All Calls, Forward Busy, Forward N/A, etc.).
Jul 10, 2014 | Comdial Impact SCS 8212S Corded Phone
How do you check voicemail on the comdial 7260 edge 120?
There should be a voicemail/Vmail button on the phone. From there, you dial in the extension and password.
Jul 02, 2014 | Comdial 8324S-PT Corded Phone
Programing
Try Googling (comdial)(8124S)(manual) without parens to get instructions.
Sep 30, 2017 | Comdial Impact 8124S Corded Phone
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
How to transfer calls between extensions
You have the ability to transfer an outside call to any extension within your phone system.
1. Press the [TRNSFR] button during your conversation
2. Dial the desired extension or press one of the Direct Station Select (DSS) buttons
3. One ring will be audible a transfer is successful. Otherwise, two rings will be heard
4. Any extension can pick call transfer
5. The Call Transfer mode will automatically cancel after 10 seconds if no transfer number is dialed
Sep 24, 2009 | IBM Corded Phone IBM412CID
How to establish extensions?
The extensions start at 10 , and if you press the speaker button and hold it for a second or two it will show the extension number in the LCD display . If you do not have any phones with a display you have to find it by pressing the intercom button and try dialing the extensions one by one .
Jun 19, 2008 | Comdial Impact 8012S Corded Phone
Comdial 7260-00
This will fix your issue
Do this:
Feature # *
Hit # (8) times
Hit show
Enter 04-05-101~156 (101~156 is whatever extension number you are trying to change)
Press chg
Use the keypad to change the name pressing # after each letter
When you are done entering the name make sure you press # after the last letter or it won't show
pick up and hang up the handset
DONE
Apr 04, 2008 | Comdial 8324S-PT Corded Phone
Lands Phones Logo
746 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
