Microsoft Xbox 360 Console Logo
Posted on Oct 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upon turning on xbox 360 power light has a red circle
Anonymous
Level 2:
Filmmaker:
Uploaded 5 video answers.
Scholar:
  • Expert 82 Answers
  • Posted on Oct 23, 2010
Anonymous
Expert
Level 2:
Filmmaker:
Scholar:
Answers
82
Questions
Helped
12806
Points
185
On the ring of light there are 4 lights
1 light = hardware malfunction
2 lights = overheating
3 light = RROD (red ring of death) your GPU has come loose
4 lights = a/v cable is loose/bad
4helpful
3answers
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
On the main unit in the center instead of a green circle i get a i/4 red circle
check video conection and power brick connection if power brick is red you need a new power brick 4 red lights is a failed av power conetion then its a uncovered by warrenty red ring of death but thats really rare best of luck if its dead look for a 4 rrod repair guide or call 1-800-4my-xbox
When I switched on the power button , instantly following which an orange(red) light circling the power button lights and remains as it is at times 3-quarter of the circle and at another instant the full...
your xbox has crashed .Sometimes if you power it down all the way you can reboot, unplug at the console not at the wall beacause there is stored energy in the transformer and you wont get a true power down, good luck
I have problems with my Xbox 360 everytime i turn on the 360 there is a red circle. I tryed to fix it but it just won't work anymore how do i fix this Problem
Is there three red lights???? or a complete circle???? Three lights is the red ring of death. Four red lights or a circle is either a bad a/v cable (try a different one) or a bad hard drive....(try taking it off of the side when power is off then turn it on.).
When I try to turn on my xbox 360 my controllers do not connect to it. I get the green power light on the front of the xbox 360 and four flashing green lights on my controller. I have tried my...
Press the circle button in front of your xbox 360 and at the same time press the small circle button on your controller ( located near the port where you connect the play and charge kit cable) so they can sync with each other
Xbox 360 is showing 3 red lights
Try this website
http://www.everything4360.com/Xbox360_3_red_light_fix.html :
When trying to turn the xbox on the circle that lights up is now lighting red
That is called the red ring of death. I don't own an XBOX 360 but I would contact Microsoft. Some XBOX 360 have been covered by an extended warranty because So many of them have had this problem. To my knowledge there is nothing you the user can do to fix this type of problem
Good Luck
6answers
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Red lights flashing
it is rrod hardware failure call 1-800-4myxbox they will fix it free
Xbox 360
okay its called the red lights of death. there are 2 ways to fix it. one go to this website. www.xbox360-fix.com orif you are under warranty send it to microsft for a free fix.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
