Question about Nokia E63 Cell Phone
My phone shows insert sim some times. - Nokia E63 Cell Phone
5 Related Answers
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: insert SIM error in nokia 11oo
your mainboard is having a problem reading your simcard.....you will need to take the phone to a mobile service center and have them either replaced or reflash the phone to correct the issue.....hopefully it is still under warranty and the fault was not cause by you the customer.
Posted on Nov 16, 2008
manojro
Manoj Rout
  • 495 Answers
SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Posted on Nov 26, 2008
Anonymous
  • 94 Answers
SOURCE: MY PHONE NOKIA3110 SAYING NO SIM CARD INSERTED.
If Nokia said it can not be repaired, it can not. Buy another phone and insert your Sim card in to the new phone so you'll have most of your data at least.
Posted on May 18, 2009
Arturo D'Souza
  • 133 Answers
SOURCE: insert sim problem 1100,1600
sometimes it is as simple as cleaning the sim card and sim points on the phone with a pencil eraser. sometimes it is related to a simcard IC (usually placed close to the sim tray in the phone) so if u do not succeed cleaning the sim and sim points of the phone u need to change the simcard IC
Posted on Jul 02, 2009
Anonymous
  • 267 Answers
SOURCE: insert sim problem in nokia 1600
ok did the sim card go with this phone origanally?
if not you will need to flash the card so that it works with this phone.
Posted on Nov 14, 2009
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Insert sim problem in nokia 1600
Nov 14, 2009 | Nokia 1600 Cellular Phone
I have problem with my sony ericsson c510 cell phone, when I insert a another sim card it says insert correct sim, now what can I do?
when my c510 mobile is on it shows "inactive sim".... after some time its working properly... while any call is received it will suddenly show "inactive sim" and become restart then show then it show "insert sim".... what can i do for this problem........
Sep 26, 2009 | Lands Phones
Sim card in . but comming up insert sim
If it still showing insert sim, you can get a rubber eraser and erase the sim's chip. Also rub eraser on the part of the phone where sim is inserted.
Try to insert other sim cards if it is showing the same error. If yes, then you need to clean that part of the phone where sim is inserted. Try the rubber eraser technique. If it does not work, have a soft earbud cotton and dip in alcohol then gently rub it on that part.
Sep 01, 2009 | Motorola Mobility L6I Cellular Phone
Insert sim problem 1100,1600
Jul 02, 2009 | Nokia 1600 Cellular Phone
My phone is telling me to insert sim and it is inside
Friend, it is very simple don't be worry. INSERT SIM when the sim card terminal is not properly connected or contacted to your sim card. Check whether the terminal connector of the SIM is properly in place. Bend it slowly if neccesary inorder to get a close to the sim so that sim card error will be prevented. Just do it friend it will be fine.good luck
Jun 16, 2009 | Nokia N72 Cellular Phone
Apr 05, 2009 | Nokia 6111 Cellular Phone
Nov 26, 2008 | Nokia 6080 Cellular Phone
Insert sim massege
Try to reset the (?make/model?) phone to original settings, if you can access the menu without the SIM card. The reset to factory settings will be there somewhere.
Feb 05, 2008 | Cell Phones
Nokia E63 Cell Phone Logo
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
