The codes on my Armana furnance is saying I have a open primary. How can I fix this?
If you have an open primary wire, this means the transformer, or one of the Hot wires coming into the unit may be tripped. Check your breakers to see. If it is the transformer at the furnace, the primary side is the 120 volt side of the transformer. The 24 volt side will be dead due to this, as it is the secondary side. If you find you have power going to the indoor unit, but nothing is working, you will need to replace the control transformer. It is 120 Volts primary side X 24 volts on the secondary side. They only cost about $20.00 and are easy to change out. Primary side you will have a blk and wht wire. You may have several wires on the other side, but it will tell you in the directions which 2 wires to use to get 24 volts, very east to do. Look on the diagram and it will show you where the transformer is at the start of the run on the furnace. Again, it may be a blown fuse if you have a fuse box, or a tripped breaker. It will be the incoming side, that is the primary. Please rate me on my help to you.
Shastalaker7
A/C, & Heating Contractor.
PS, If you need my help contact me.
