Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
Dane-Elec 4G USB thumb drive is not found by win Xp or Vista. It is brand new out of the package. Any suggestions?? It seems like the driver is missing???
Posted by jenmaycroft on
ikkenom
    Brigadier General:
  • 10,406 Answers
Try connecting it to a different computer.
If it still is not detected, then it is "DEFECTIVE".
Take it back to where you bought it, and get them to try it in one of their computers, and then to replace it.
Posted on Oct 24, 2010
How to download from a dane-elec thumb usb into my computer. I had loaded family photos on it a year ago.
You should be able to do it by just connecting it to your computer.
Assuming you have a windows computer it should try to install the drivers and then it would be available on the "My Computer" folder.
If it is not recognizing the thumb usb when you insert it in your computer (nothing seems to happen) then go to: http://www.dane-elec.fr/index.php?option=com_content&view=article&id=27&Itemid=95&lang=en
and download and install the drivers.
Let me know what operating system you are using (windows xp, 98, vista, 7, etc..) if you run into any problems
Mar 16, 2011 | Computers & Internet
My DameElec 2GB is not working on my XP Computer
try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Jul 17, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Is the dane elec 2gb drive compatible with windows 7? It only says up to vista.
generally yes, the Dane Elec drives work fine in windows 7, i have 2 of these drives, 1 512mb and 1 8gb, and they both work fine in
windows vista windows 7 Linux Macos
May 24, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Have Dane-Elec 4 MB USB; works in one CPU great, in the other, I had to reboot, and then when I look at "My Computer" it appears and disappears every few seconds and I can't access it. Running XP both...
In Control Panel, click on "System." When the System dialog appears, Click on "Device Manager."
In Device Manager, click on "Disk Drives." That should drop-down and reveal your USB drive as a USB device.
Right click on your USB device and click uninstall, then reboot.
This procedure will uninstall the drivers for your device. After rebooting insert the USB drive into a port and a "Found new hardware" window should popup. allow internet access and reinstall the driver--this should be pretty much automatic; just make sure you allow the program to search the internet for the latest driver.
Good Luck!
Feb 21, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Missing driver for dane elec 4gb usb flash pen (Operating system XP)
No zMate Pen driver is necessary to work out with Windows Millenium, Windows 2000, Windows XP and MAC OS 9.1 and more: they are plug and play.
but try this site:
http://www.dane-elec.fr/scripts/home/publigen/content/templates/TPL_ADV_INFO_C2_S4.asp?P=352&L=EN
Jan 11, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-elec usb portable memory stick - right protect error
pu *** into you rown pc again and format it. when it is done formatting reboot your pc and let usb in while rebooting. when its done you can use it again but when used take it out with "safely remove hardware" option.
hope this helps otherwise they have a return and guaranty service at least
sorry for grammar but im not english
Jan 02, 2009 | Dane Elec DANE-ELEC DA-M4-04-ML2 Meizu 4G...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
380 people viewed this question
Top Dane-Elec Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Hetman Software
Hetman Software
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
