Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Unfortunately, there is no way to recover a lost or forgotten password
from a router or access point; you will need to reset the device to
factory defaults. However, once the device is reset to factory defaults,
you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
hope this helps
password.
forgotten password from a router or access point; you will need to
reset the device to factory defaults. However, once the device is reset
to factory defaults, you can use the default username ("admin") and
See the following articles for more information:
