Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Good day, One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment. This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer. Patience and time are the most important tool you have to work with in dealing with this issue.
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
at the top of the fridge section at the center back there is a drain assy/ tube for defrost water to exit the unit and go to the bottom of the outside, this is most likely clogged up. disassemble and clear drain line, hook back up and call me in the morning.
