Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Posted on Oct 22, 2010
Testimonial: "thanks! it is the kerosene heater. i ordered the low pressure gauge and will check pressure. motor cuts out and you hear the safety switch click."
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 06, 2011 | Master Heaters 160-IF
Dec 23, 2010 | Reddy R155D Utility Heater
Dec 14, 2010 | Reddy Heater RH125T Kerosene Forced Air...
Feb 03, 2010 | Reddy Heater-30-55,000 BTU Variable
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Dec 23, 2009 | Reddy Heater 60,000 BTU Kerosene...
Dec 08, 2009 | Reddy Heater RLP100 Portable Forced Air...
Mar 09, 2009 | Reddy Heater 60,000 BTU Kerosene...
Feb 09, 2009 | Desa International Reddy Heater R115DT...
Jan 21, 2009 | Reddy Heater-30-55,000 BTU Variable
555 people viewed this question
Heater will not light, filter is clean, transformer good, pressure switch good, what else to look for
