look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Look closely at the jack for the microphone and you can see the small numbers that are on it. On the Roadking red and shield (bare) go to 1. White 2, Blue 3, black 4 and the yellow in the cable does not connect to anything.
take a wire or small screw driver across any two pins you are looking for a earth from tx to tx the last pin is mic. on mic side use a multimeter earth is braid, find rx lead next . key mic multimeter shows 0 tx. audio has a higher value .
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
