Water Heaters Logo
Anonymous Posted on Apr 19, 2017
I inherited a Worcester Highflow 3.5 GC 41-311-39. The motor for the diverter has failed, so I can only get hot water by turning on the tap, then switching on the hot water on the boiler and heling the motor. I'm unable to find a manual/part number and would prefer to replace the motor only rather than having to drain everything - the boiler is in the garage and lower than every radiator - about 14 in all! Any suggestions on part numbers and procedure? It looks like front & side panels off then a flat screwdriver will get it. Thanks, in advance. Robin, Blackburn Lancashire (UK)
Paul Carew
Level 3:
  • Bosch Master 3,807 Answers
  • Posted on Apr 19, 2017
Paul Carew
Bosch Master
Level 3:
Answers
3807
Questions
Helped
1298632
Points
10523
It may well be a honey well which you can just change the motor . The top cover should come off 1 screw holding it and lift off you should see the motor there . Most plumbing and heating shops will stock replacement motors .
3 Related Answers
Anonymous
  • 234 Answers
  • Posted on Mar 19, 2009
SOURCE: Need free Worcester Highflow 3.5 user manual
http://www.worcesterbosch.com/
Anonymous
  • 15 Answers
  • Posted on Apr 11, 2010
SOURCE: worcester combi gas boiler 3.5 highflow is
water vapour is one the main products of combustion of gas. With a standard efficiency boiler, upon initial heat up when the flue is cold this vapour can condensate on the inner wall of the flue but should stop once the flue heats up, to stop this condense dripping back on to the heat exchanger the flue should be tilted towards the outlet and thus on initial heat up water can drip from the flue. with high efficiency (condensing) boilers, condensation will occur in the flue and secondary heat exchanger during normal operation, dispense of this condensate is accommodated for in the boiler and therefor the flue should be tilted towards the boiler, if not the flue will drip constantly.
Anonymous
  • Posted on May 17, 2010
SOURCE: Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
1helpful
Replaced diverter valve on worcester 9.24 combi and still only luke warm water
check your expansion vessel is not flat.if so recharge..simple way to check press in valve on vessel if water comes out or little air recharge..if water still in vessel the diaphram in vessel has split so replace vessel?hot water relys on expansion??
Hello, I have a Worcester 24i boiler and the heating is working fine but the hot water will only stay hot for about a minute at a time in the kitchen sink, the shower is ok but only when the heating is on....
http://homeguides.sfgate.com/flush-out-tankless-hot-water-heater-53060.html
The link is to how to flush a tankless system.
This should be done once a year.
https://www.manualslib.com/manual/554372/Worcester-24i-Rsf.html?page=2#manual
This link is to the manual on the unit.
On my unit, it the hot water is running slow the unit turns off and the hot water goes cold, so for me its run the water on full.
I have worcester 24cd1 and no hot water but heating works fine, was told it could be the thermocouple??
No. this will be the diverter valve and the large rubber diaphragm inside split,, holed or just worn out. Replace
Confirm by operating a hot tap with the heat NOT on.
Do you hear the gas valve click. If not confirmed
1helpful
Worcester 24i combi when in shower hot water flicks on and off can hear gas igniting and extinguishing
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
