Question about Garden
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Posted by lynellemason on
Beverly Gilbeau
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Posted on Aug 05, 2014
4 Related Answers
woobie dog
woobie dog
  • 1273 Answers
SOURCE: How do I change the
Hi, W/D here.
The blade changing is accomplished by pushing the yellow button and pulling the old blade out. It is reversible. If there is no blade at the ready, there may be more in the body of the knife, which are located behind a swing out panel on the handle. You'll need to push in the yellow button when installing the blade, and once the blade is in, release the button, and moge the blade until it clicks in place.
--W/D--
Posted on Jan 21, 2011
kirkx
Kirk Augustin
  • 2019 Answers
SOURCE: How do you put blades
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Posted on Feb 26, 2011
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: How do I snap off
The safest way is to put on safety glasses,extend the blade to just beyond the next line, grip the blade with a pair of pliers at the line with the edge of the pliers parallel to the line and give the pliers a twist. The blade will break off cleanly.
Posted on Apr 03, 2011
William R. Best
  • 3 Answers
SOURCE: Stanley 10-801 utility knife. How
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Posted on Aug 03, 2011
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Mar 06, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-801 utility knife. How do you change the replaceble blade?
Nov 26, 2010 | Stanley Garden
How do I put the first blade in the new knife?
open the blade all the way and turn the knob to loosen, then scissor the two halves to open
Oct 22, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Change blades I just need a picture /instruction for blade change
The gold looking circle on the side of the utility knife. Just unscrew that and it will pop open then you can change the blade. I looked everywhere and am unable to find the instruction or picture. I own one and that is why I am answering this for you. Please rate
May 31, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Jan 14, 2010 | Hand Tools
Stanley knife blades fell down drum and under
Probably the best thing to do in this situation is to empty the washer out, then unplug it and turn the water off at the spigot.
Then invert the washer, leaning it back, so as to reach the blades under the drum.
Mar 04, 2009 | LG WFT1071TP Top Load Washer
Garden Logo
419 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
