Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
I suspect the problem lies with the HP software on your computer. You can download the HP Photosmart software from www.hp.com. Look for Software & Driver Downloads for R707 camera. You can still transfer your photos by setting USB Configuration in your camera, to Disk Drive in the Setup Menu.
Download HP Photosmart software from www.hp.com under Software & Driver Downloads for R707. You can download your photos by setting your camera USB Configuration to Disk Drive in Setup Menu.
To transfer the photos, connect directly SD card to your PC through a card reader.
Try to reset your HP R707 camera: remove the battery and press the reset switch for about 5 seconds. Reinsert the battery.
You can transfer the pictures from your camera by setting the USB Configuration to Disk Drive in the Setup Menu.
I suggest you to reinstall the HP Photosmart software from Software & Downloads on www.hp.com.
get the adapter plug it in,, in the camera that little hole next to the usb,,, just like u will charge the battery, then turn the camera on,, just your camera lens will be back to normal,, hope i helped ya out.
Cracked screens in the r707 is easy replacement. I just tend to swap
screens from another r707 that has a lens issue. I have noticed that
there is two types of LCDs in the r707 camera. One is easy type to
replace because all it has is a serial cable that is attached circuit
board. The other is a little harder because it has, besides the serial
cable, two additional wires that are soldered to the board. The lcd is
actually attached the black half of the camera's case. You will have to
remove all of the screws and then remove the front (metallic) half of
the camera. There are two cables that attached the camera circuit
board. One is the LCD and the other is button/SD flash board; both of
which are attached to the back half of the camera's case. Remove the
back case and swap out the LCD and reattach everything in the reverse
order of dissassembly.
