Question about Fuji FinePix F410 Digital Camera
We have a Finepix F410. The trouble that we are having is printing off photographs that have the date imprinted. The date is on the camara display and is in the "on" mode. Any thoughts??
Posted by awd684 on
dgsturt
    Guru:
  • 1,705 Answers
The Date and time is saved more or less as an add on to the picture file, not as part of the picture itself. So you're not going to get a date printed when you print the picture.
If you RMB click on the .jpg file when its on your PC, and select properties, it will also show the date. Until you edit it that is.
The only real way around it is to A) Buy a camera which has the option, B) Edit the photo, adding the date prior to printing or C) Write the date on the back as we used to have to do.
Posted on Oct 21, 2010
How can I set the photo in wnich date can be seen
The date and time (and a lot more) are automatically stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 24, 2013 | FUJIFILM FinePix AV100 Digital Camera
NIKON D7000 DATE IMPRINT
D7000 will not deface your photographs by scrawling a string of numbers across them. However the date and time (and a lot more) are stored with each image in the file's EXIF metadata.
If you want to print this information, please consult the documentation for whatever program you're using to print your photos. Depending on the program and printer, you may print this information on the image, in the margins, or on the back. For example, if you're creating a DPOF on the D7000 itself, the instructions are in the "Creating a DPOF Print Order: Print Set" section of the camera manual (page 189 in my copy).
Apr 04, 2012 | Nikon D7000 Digital Camera
DATE IMPRINT IN D7000
Neither the D5000 nor the D7000 will deface your photographs by scrawling a string of numbers across them. However the date and time (and a lot more) are stored with each image in the file's EXIF metadata.
How to print date on photo - finepix s5600
Go into the settings of the camera and look for anything called "Date/Time Stamp." Enable this setting and the date will be printed on every picture. Be careful, though. Date/Time Stamps are not easily removed so make sure you want it on whatever you are photographing.
Hope this helps.
Feb 28, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
I have a canon sd600 camera. how do I imprint date and time on the photograph
The camera settings menu should give you the choice whether you want to imprint the date or not. However did you know that digital photos have an invisible exif data file attached to them. It gives you information about the camera model, date, time, exposure etc etc. Some photo viewers like irfanview can show you this file and you need not spoil your photos with a date imprint. ( depending on what they are an imprint can be useful or distracting) .
Dec 24, 2010 | Canon Cameras
How do I get the date to imprint on my photos?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Dec 04, 2010 | Fuji FinePix A360 Digital Camera
Print date on photo
see page 55 of the user manual - link below
Here is the user manual http://www.fujifilm.ca/documents/Fuji_Z2_CM.pdf
  1. Press the “w” button to turn the camera on in Playback mode.
  2. Press the “MENU/OK” button to display the menu on the LCD monitor.
  3. Press “a” or “b” to select “¸” PRINT ORDER (DPOF).
  4. Press “c”.
  5. Press “a” or “b” to select “WITH DATE” or “WITHOUT DATE”. Selecting “WITH DATE” will cause the date to be imprinted on your prints.
  6. Press the “MENU/OK” button.
Note: When selecting the “WITH DATE” setting, the date is imprinted on your shots using the Print Service or a DPOF compatible printer (depending on the printer specifications, the date may not be printed in some cases).
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Fuji FinePix Z2 Digital Camera
Date imprint on photocamera
The EOS range does not automatically "imprint" the date/time on the images. Being digital, most of the information can be found in the EXIF data anyway. If you want to print the photos with the date at the corner, I believe ZoomBrowser EX has that function. ZoomBrowser came with your camera amongst a few other CDs (eg Adobe Photoshop Elements, DPP etc)
Jan 07, 2010 | Canon EOS 30D Digital Camera with 18-55mm...
Date and time imprinting
You can't. That model doesn't have that function. If you ask your photofinisher, they may be able to do in for you during the printing stage (Fuji Frontier labs have this function). If you are printing at home, your printer may have that as a selectable option.
Oct 06, 2008 | Fuji FinePix S7000 Digital Camera
Cannot imprint date
Sep 18, 2008 | Pentax Optio A10 Digital Camera
Fuji FinePix F410 Digital Camera Logo
55 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Fuji Camera Expert? Answer questions, earn points and help others
