Question about Apacer Memory AU822 MP3 Player
Hi. My AU822 is not recognized by my Win7 x64 OS. Sound of USB connected device sounds but it does not shows the device in My Computer. I was trying to find driver for resolving the problem but with no success. Firmware solution maybe? Please give advice or solution :) Thanks. P.S. it is recognized on my girlfriends XP notebook.
  • Anonymous Dec 17, 2010
    I can not link to this address. DSN error... Thanks anyway :)
Anonymous
    Can't link to it. DNS error. Thanks anyway! :)
Windows 8 x64 doesn0t show usb flash drive in windows explorer
It will only show USB devices that have been formatted. Have you tried going into the Computer Management, Disk Management to see if the usb drive is recognized? Can another windows PC recognize the USB drive?
Aug 17, 2014 | Electronics - Others
ML 2240 printer not detected by Windows 7
Try installing it in safe mode.
To go to safe mode, do the following:
Restart and tap F8. Use the arrow keys to highlight safe mode with networking and hit enter. Install the driver from there and follow the on-screen instructions.
If no go, check the device manager of any question mark. There might be some outdated drivers that cause this problem. You can use RadarSync (free version) to scan your computer for outdated drivers.
After fixing all driver related issues, try installing the printer again.
I hope this helps!
David
Feb 25, 2013 | Samsung ML-2240 Laser Printer
Windows 7 will not recognize my v6upl scanner which worked in Windows XP. Problem seems to be that Device Manager sees it as an Unknown Device under the Universal Serial Bus controllers.
Unfortunately, Microtek doesn't support the V6UPL for any Windows OS beyond XP. The drivers are available here: http://support.microtek.com/downloads/bycategory.phtml?slct_tbl=1&slct_mdl=2 .
What version of Windows 7 are you running? Click Start > Control Panel > System and Security > System. If the version name ends with x64, you have the 64-bit version; otherwise you have the 32-bit version.
If you have the 32-bit version, try using the driver from the above site with the compatibility mode. Right click on the .exe file and choose Properties. Then select the compatibility tab. Set the program to always run in the compatibility mode for XP. Then right click again and choose Run as administrator. (You may need to disconnect the data cable and uninstall the Unknown device before trying to install the XP driver).
This will probably not work for Win7 x64. There are workarounds that you can use. You need to connect the scanner to a computer running an older version of Windows. This can be a physical second computer, a dual boot computer or a computer running a virtual version of the older OS. If you have Win7 Pro or Ultimate, or upgrade to one of those versions, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. Then install the XP scanner driver in the XP mode program as if that is the only computer running. The only issue is that you can't share files or your printer between the virtual and real computer at the same time. You will be prompted to uninstall the printer if you try to install it on both machines. You can put files on external media to share them. Other virtual computer programs are Parallels and VMWare. However, you need a licensed version of the older Windows OS to use any of the other alternatives.
I hope this helps.
Aug 18, 2011 | Microtek ScanMaker V6UPL Flatbed Scanner
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Hello, i just came home with a brand new ink printer HP Deskjet 1050. I installed all drivers and software (printer, scanner and some help software). when i connect it to my laptop, i receive a usb...
while installing u must get a message to connect the printers usb.
if u dont get so try the default printer driver with the OS. means dont install the cd which came with the printer istead go to startup, devices and printer and try alligning. might work.
Dec 06, 2010 | Computers & Internet
Hi, i just recently upgraded my OS from winXP to win7. However, after installing win7 i couldn't get any sound from my pc. Device manager says that the driver is working fine. I checked the settings of...
go to control panel then hardware and sound then go to manage my sound devices under that will find playback under that you will have to click on speakers(single click) and and then the configure option gets activated then you have the option to check the speaker functionality and also you can go to sound tab select a sound and click on test to check it
Oct 27, 2010 | Realtek Semiconductor Realtek High...
Driver for vista x64
Today I installed VueScan on my Win7 (7264) X64. After that the 1250 was still not recognized. Go to start and execute/run devmgmt.msc. You will get the hardware list with a yellow marker on your scanner driver. Double klick on that icon. Now you need to go to the second tab (driver program if I translate it) and second button (renew if I translate it) where you can install drivers for the device. Tell windows to search on your computer and point to the VueScan directory (directly on C: , not in programs). Now Windows 7 (7264) X64 will find the driver and your Epson 1250 is recognized. :-) Tested and working.
This same method worked for installing the AlexP drivers for my PS3 Eyetoy on windows 7 (7264). Tested and working also.
OoZic
May 08, 2009 | Epson Perfection 1250 Flatbed Scanner
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Apacer Memory AU822 MP3 Player Logo
199 people viewed this question
Top Apacer Memory Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
vinayghl
Tom Chichester
Are you an Apacer Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
