Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
You need to Pull Lamp out and Look inside at Color Wheel ,Make sure it is OK and not the Same Problem.If it is OK,Then Look at Ballast Board see if it is Arking if so replace the Lamp.
Encompass Parts Distribution 1-800-638-3328
Mats Electronics has Lamps $99.00 1-800-628-1118
Posted on Oct 21, 2010
Testimonial: "I greatly appreciate your time and expertise.. however I would like some clarification if I may? "
If I am to see visually if the Ballast board is ARKING as you say, then I am to infer I need to have the back off or the lamp door off while turning on the tv? Is this possible? If so is this safe? I have pretty much assumed my next step would be to replace the lamp, however with the noise and all I was unsure I would be able to fix it. If I just need to replace the lamp this is good news. After posting this I had left the TV unplugged for about 10 or so hours and later plugged it back in and turned it on and it came on with no problem??? Weird huh? I am fairly confident that it is the lamp however and I will simply need to shell out the money and replace it. If you or anyone else have any insight into this and can confirm or change my thoughts on this I would be greatly appreciative. Thanks again. W.
Lamp PN# BP96-00224A
Encompass Parts wants $150.00 for Lamp
I found Lamp for my samsung on EBay for $85.00 shipping Free
Look under Electronics TV/Parts type in Lamp #
PS. I would replace the Lamp. Lamps last between 5,000-8,000 playing hours,when lamp is going bad set will play for so long then turn off and finally Tv will not come on.
Thank you so much for your time and expertise... I will check on that.
I intuitively thought that was going to be the solution, I greatly hope that is the "FIX" and my tv I bought originally from a friend for $300 will continue working for a few more years? Not bad considering $300 and additional $120 for the color wheel so far? I think I will still be ahead if I only have to replace the Lamp. Ok, thank so much once again. Your help has meant a lot. Have a great day. Regards, Seagoat51
Just in case you didnt Know ,The TV you have Cost $2,990.00 New
I did know that, thank you though.... LOL... I know I got a steal on it. MUCH THANKS again for your time.... CHEERS!
Jan 14, 2015 | Samsung Televison & Video
Aug 13, 2011 | Samsung HLR5064W DLP Projection TV
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Oct 05, 2010 | Samsung HL-R6167W 61" HDTV
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
Oct 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
464 people viewed this question
test
