Question about GE Lands Phones
My replacement handset that I just received came not registered. I followed instructions to register and it keeps saying registration failed. What do I do
  • 1 more comment
  • Anonymous Oct 21, 2010
    I need step by step instructions. I have no understanding of this type of thing.
    It is still telling me that the registration has failed. I just spent 38.00 for this brand new replacement handset and now I can't use it. what should I do to get it registered?
    Problem is not resolved yet.
Jose Cada
  • 3,530 Answers
All you have to do is place the second handset in the main base (the one connected to the phone line) after it's charged for the 16 hours in its own base. Leave it there for about 20 seconds, and check to see if the phone has a dial tone. Then, the "please register" message should disappear and you can re-name your second handset if desired.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Oct 21, 2010
  • Jose Cada
    Jose Cada Oct 21, 2010
    Try and retrieve battery then put it back.
    Push program key: registration: yes (program key) then press page key on base then program key on handset when it beeps.
  • Jose Cada
    make sure that the battery is fully charged when doing this.
Muzahura Frank
  • 2,069 Answers
You could register it from the bases cradle if its completely compatible.
  • Muzahura Frank Oct 21, 2010
    ok post exact model so that i give you specific instructions
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
1. press [menu]
press [select]
(this is why the cover was off)
replace the cover
( II.) To clear the base of all handset registrations
blink. 2. release the [Find Handset] button momentarily,
ready for fresh registration ===============================
( III.) To register each handset to the base:
"Handset #x" or it will say "Registration Failed".
few hours and try the registration ( III ) again.
Good luck !!
Apr 16, 2016 | Vtech Accessory Handset with Caller ID for...
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
In that case, you can clear each handset ( I ) then clear
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
replace the cover
( if needed, else skip ahead to ( III ). )
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
How do I register my vtech phone?
"Register" refers to the pairing of the handset to
the base so they can communicate securely
in private via an encryption scheme so no one
can easily evesdrop.
When you first set the phone up for use, you will
need to effect the registration then:
Good luck !!
Jan 03, 2015 | Vtech CS6829-26 2 Handset Answering System...
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Tried to reregistering
Hi
Please try the following procedure:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 27, 2009 | Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Lands Phones Logo
100 people viewed this question
Top GE Lands Phones Experts
Bruce Robin
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
