Sony Cyber-shot DSC-T70 Digital Camera Logo
Posted on Oct 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to use change resolution - Sony Cyber-shot DSC-T70 Digital Camera
Anonymous
Level 3:
  • Master 455 Answers
  • Posted on Oct 21, 2010
Anonymous
Master
Level 3:
Answers
455
Questions
0
Helped
153728
Points
1043
The screen resolution of the Camera cannot be changed. The option in the Camera is to change the Image size which will increase the MegaPixel rate of the Camera. This can also be called as resolution. This can be changed by touching the Image Size icon displayed on the Camera screen. The settings available for Still Image Settings and Movie Image Settings in the DSCT70 Camera are given in the image given below:
Thanks,
KenSolutions
FixYa
I changed the video format on my night owl DVR and now I cannot get it to display on my tv. An error message appeared on the tv stating "resolution mismatch! change devices resolution"
hi,
maybe when you changed the video format the resolution of the screen was changed or
the new format needs another resolution.
try to change the resolution of the screen
daniel
https://www.rylwy.com/
How to change the resolution
  • Native Resolution - 1280 x 1024 at 75 Hz
  • To change your screen resolution
  • Open Screen Resolution by clicking the Start button , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  • Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  • Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
  • if not display come pls select esc button to revert resolution.(don't press Enter)
Change screen resolution
Hi, remember that there is only one resolution on tablet.
there is application that does interpollation (false resolution redimmention)
http://www.redmondpie.com/change-screen-densityresolution-of-your-android-device-with-lcd-resolution-root-only/
hope this can help.
Change display properties
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  3. Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
c976c8e1-2a05-4209-a850-ea7c43422c04_50.jpgScreen Resolution in Control Panel shows the recommended resolution for your monitor.
2helpful
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
How can i change the resolution on my hp laptop's cam.
You can't change the webcam resolution, but you can change the recording resolution in some programs. I use Debut for recording webcam pictures and videos and it allows me to change resolutions. Video chat services don't let you change it as they limit the resolution to save on bandwidth.
4helpful
2answers
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
1helpful
Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
No. You cannot change the resolution on any MobilePro Desktops. The VGA out is also fixed and you cannot change the external resolution. Only the MobilePro 770 and MobilePro 800 allow you to change the resolution on the VGA Output.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
