Question about Kenmore 72293 - Stainless Steel Top Freezer Refrigerator
Why water dripping from where cold air come down from freezer section into the refrigerator section? The setting is about the same. Both sections are working except the leaking that are from all three area left and right side square hole as well as the center tube like area.
Posted by el1168 on
D. Floyd Kolb
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
There is a drip coming into the refrigerator from the ceiling , but the freezer is not frosted
I suggest that you remove the bottom layer of the freezer - you'll see its just a piece of plastic to allow cold air to circulate underneath. There is a metal tray in the back of the freezer there that has a drain in it - I'll bet its frozen solid and the condensation from the defrost cycles are dripping down into the fridge part.
Nov 16, 2011 | Haier HTE18WAA Top Freezer Refrigerator
TOP AND BOTTOM NO AIR FLOW UP TO FRIDGE FREEZER IS FINE EVAP FAN IS WORKING DAMPER IS OPEN
all i can think of is the door was left open and the air ducts are frozen,look in the freezer section,do you see any frozen water droplets on the walls.ceiling or on the food packages?mostly happens on bottom mount fridges,the warm air gets blown up the air ducts and along with the cold air the ducts freeze up and no air will blow into the fridge section,you can unplug the machine and blow into the holes in the back wall where the evap fan is,if you start to see water dripping down through the air holes keep melting it out until no more water is dripping,then turn it on and feel inside where the damper is and you should feel cold air,this could take a while depending on how much ice is in the ducts.
May 11, 2011 | Refrigerators
I have a magic chef refrigerator that is not cooling. The freezer is working but nothing is staying cold in the frig. Could this be the thermostat?? Don't want to replace frig for a number of reasons. ...
next time send the model number,where is the freezer is it on top or bottom or side by side,anyway all the fridge does is get cold in the freezer and the evaporator fan blows cold air from the freezer into the fridge section and then it returns to the freezer just goes around until it gets cold enough and then the t-stat tells it to shut down so if the freezer is cold you either have a bad fan motor,open the freezer you should hear the fan blowng around in there if not the evap fan motor is bad,also touch the back inside wall of the freezer if there's any frost or ice on the back inside wall you have a defrost problem,bad timer or board,bad defrost thermostat or a bad defrost heater,the ice doesn't melt off of evap coil because one of the parts have failed,the air ducts get blocked with ice and the cold air can't blow into the fridge section,or if you see ice on the ceiling,side and back walls the door was left open and the air ducts blocked with ice,or one more thing if the freezer is on top and you have water dripping into the fridge section the drain in the freezer is blocked and the defrost water can't go down the drain hose,the water is freezing the air ducts up,the drain has to be cleared and all the ice has to be melted out,and yes there is one more thing it could be, some fridges have a damper in them,all it is is a door that opens and closes to let the cold air from the freezer blow into the fridge section so this is why you have to send the model number.but your problem is the cold air in the freezer isn't getting blown into the fridge section because the fan isn't working or the air ducts are blocked with ice.
Dec 31, 2017 | Refrigerators
The freezer section is defrosting continuously and water is dripping down through refrigerator and on the floor.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 05, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
Model ET1MHK XTM04- Water dripping down into refrigeration section, freezer section has frost build up. Temperature set at 3 (mid).
Hi pgtc;
Just check and make shore the door seals are completely sealing. If air is been sucked into fridge it shall create water, same as freezer frost is created by air been sucked in.. Oh thats as long as the freezer is working -18deg.. Cheers
Mar 28, 2010 | Whirlpool Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator is not cold enough.
I had this repaired by replacing the motor-fan in the refrigertor behind the air deflector which sends the air from the freezer to frig. hope this helps. The motor was not working.
Aug 03, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Does the single temperature control guage affect both,freezer and
check in the freezer section for a knob to control the freezer. Turn this knob back to center and return refrigerator setting to 5. What is happening is the freezer control is just a baffle that divides the air flow into the fresh food and freezer section. If the freezer knob is turn to 1 or cold it is sending all the cold air into the refrigerator, then when you turn down the actual cold control, the system isn't allowed to run long enough to allow the freezer to stay frozen.
Jun 19, 2009 | Kenmore 64802 Top Freezer Refrigerator
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 72293 - Stainless Steel Top Freezer Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
