Brother MFC-5840CN All-In-One InkJet Printer Logo
Question about Brother MFC-5840CN All-In-One InkJet Printer
Hi ,any kind soul to teache the prosedure to solve my Brother DCP-135C's "unable to clean error 46". many thanks
Posted by joehandres on
Nikolay Boychev
  • 525 Answers
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
3helpful
Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
When power on printer DCP 135C an error disply as clean unable 46.see troubleshooting and routine maintence chapter in user guide
I've run into this error before, and basically it means something is stopping the carriage from moving.
If you are unable to find out what is causing the carriage to not move, the printer is not economically feasible to repair and will need to be replaced.
1helpful
DCP-135C after inserting new inks message reads "Maintenance and users guide chapter 46 cannot clean" Will not print.
63helpful
3answers
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
Clean unable 46
46 says the ink absorber box and flushing box are full, you need a shop to replace these and reset the counters. It's possible to just reset the error but you risk printer damage if they overflow.
Unable to clean 46
posted fix in another prob same section
2helpful
2answers
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
50helpful
11answers
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Norman  J Weimar Jr
Norman J Weimar Jr
Gary
Gary
